Charging Systems Are Expensive!!!
I know the two codes are two different systems (charging and electrical) but I'm also wondering if somehow they're related.
Series of Events
1. The first thing I noticed that went bad was my phone charger which is spliced into a switched/fused accessory wire. (no codes)
2. A couple weeks later my hand grip heaters went out. (no codes). Since it was the beginning of summer I didn't really worry about it.
3. Fast forward a few months to winter and I disassembled my right hand grip to start testing the wires to the heater switch. Removed switch assembly, brake lever and grip.
4. The weather was too nice to have a bike sitting so when my buddy stopped in to ride on Christmas Day I through everything back together and went for a ride. During which, my engine and battery lights came on and my voltmeter was showing around 10.5v.
5. Got back home and pulled the codes P0562 (charging system) and P0572 (Brake Light)
6. I checked the brake light function for both front and rear brakes and the brake lights do not switch. Because this is the lesser of the two codes and probably just a switch, I moved on to the charging system.
7. I did a ground test on the stator. Unplugged Stator wire from Regulator and tested resistance between each of the three wire contacts and a solid ground - failed. All three contacts showed resistance when they are supposed to be Open.
8. I did a diode bench test on the regulator and found only the ground diodes are working as expected (Neg to ground/Pos to stator connectors showed resistance) All other combinations showed Open.
Based on the results, I believe I need to order a new regulator and stator. What test do I need to perform for the rotor? From what I'm reading, people suggest getting all three. However, the rotor is the price of the stator & regulator combined. I could be upward of $400 on this buying all aftermarket parts.
I thought I would check with you guys for your thoughts before I went any further. Here are the various questions:
1. Is my diagnosis correct on the stator? If I'm not getting an Open reading (ie. "1") between ground and the stator wire connectors that is a grounded stator and needs replaced - Right?
2. Is my diagnosis correct on the regulator? On a bench test, both the Lead connector (going to battery) and ground connector should have an Open reading going one direction and a reading with resistance going the opposite direction. Is there a reason why I would get an Open reading in both directions if the regulator wasn't bad?
3. Is there a test for the rotor? I don't have $200 to just throw at the bike "just to be sure", but if it's bad. I want to replace it.
4. Am I ok to focus on one code and then the next or do you think they may be related?
Thanks for your help!
https://www.amazon.com/Cycle-Electri.../dp/B0031BL680
Thanks! I'll check this out. Not sure if you saw the linked video in original post, but I really appreciated the explanation and walk through of the bench test on the VR.
Set you meter to 1X or so. Short your probes together and zero your meter. Pull them apart. What ever you see now is what you should see for each of the 3 stator leads when you attach a meter wire to them and the other meter wire to a solid connection on the primary cover or cylinder fin.
I had interpreted what you had said above in a previous post that you saw a meter change when you checked the 3 wires to a ground. If that is true your stator windings are shorted together and gone to the laminates the wire is wound around.
Make sure you are checking correctly. You can spin a lot of wheels checking wrong. Even then, it can be tricky Read this.
https://www.hdforums.com/forum/evo-c...r-reading.html
1. P0562 isn't related to P0572 - I will diagnose the latter in another post after resolving the charging system.
2. Stator is fried - I am getting a reading on all 3 sockets proving my wiring is contacting ground.
3. Regulator is fried - this was probably caused by the Stator grounding.
4. Rotor is yet to be determined - I will visually inspect this after I remove it.
My snap ring pliers don't have a wide enough span to remove the snap ring from the clutch assembly. I'll pick up a larger set tomorrow and get back at before the weekend. I'll post updates.
