Muffler install problem
Old Jan 4, 2020 | 01:19 PM
harley7316's Avatar
harley7316
Default Muffler install problem
Hoping i can get some help.Removed SE street cannon muffler just the right side.Trying to get the muffler back on and i cant slip it over head pipe.Clamp is loose and as far back as it can go.Been fighting with this for 2 hours put a bit of anti seize on the inside of muffler to help slide on no go.Any ideas?Thanks in advance
Old Jan 4, 2020 | 01:22 PM
sanman4ever's Avatar
sanman4ever
PB Blaster and muscle that thing...
Old Jan 4, 2020 | 01:29 PM
roussfam's Avatar
roussfam
Wrap some fine emery cloth around the outside of the tip of the header pipe and clean it up, then do the inside of the muffler. Then lube and reinstall. If it still gives you trouble but has started to go on, a rubber mallet or a piece of wood and a hammer will persuade it to cooperate
harley7316's Avatar
harley7316
Having a beer and will head back out to garage and give it another go
Old Jan 4, 2020 | 01:34 PM
sanman4ever
I had a set on V&H that were like that. If it came off, it will go back on. Stay on it!
Old Jan 4, 2020 | 01:41 PM
Steve N,'s Avatar
Steve N,
That's the best first step. Re-group and lower the frustration level.
Old Jan 4, 2020 | 01:58 PM
Sam2010's Avatar
Sam2010
Wd-40 spray on paper towel wipe on both surfaces slide muffler on.
Old Jan 4, 2020 | 02:20 PM
EG-2006's Avatar
EG-2006
Spit works good too
Old Jan 4, 2020 | 02:38 PM
harley7316's Avatar
harley7316
Well go it on finally the emery cloth did the trick!Thank guys for the help
Old Jan 4, 2020 | 03:21 PM
JABMIKE's Avatar
JABMIKE
Muffler end is out of round. I bought a pipe expander from Harbor Freight to get it back to round..
