Stiff clutch
Old Jan 9, 2020 | 09:09 AM
Doug2061's Avatar
Doug2061
6th Gear
Default Stiff clutch
I've noticed when it's cold that my clutch is extremely stiff, even to the point of affecting throttling on power when first leaving my driveway. This has been a little problematic, I'm accelerating through the turn and power is delayed which has caused the bike to be unstable. (No falls thankfully.) It even makes it difficult to change gears after I am on the road. I live in the south so I'm not talking extreme cold just riding in temps ranging in the 30s and 40s.Later when it has gotten warmer the clutch operates normally. Does anyone know how to address this issue. The bike is an 09 Ultra by the way. Thanks for any help.
Old Jan 9, 2020 | 11:59 AM
RK_Classic's Avatar
RK_Classic
To me it sounds like the oil your running in the primary is a little thick with temps of 30 or so, do you warm the bike up some before you leave? JMO is all.
rk classic.
Old Jan 9, 2020 | 12:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The OP didn't state what oil he is using in his primary or viscosity. As previously stated cold oil in the primary will have an effect on clutch operations until it's up to operating temperature. If this is a big concern then drop some 10W40 oil in the primary, the oil's primary job is to lubricate the chain then provide cooling for the clutch plates. You may also want to considering lubing the clutch cable.
I did take in consideration the OP's location, so once the temps start going up in the spring, change back to the previous oil.
Old Jan 9, 2020 | 12:50 PM
blackjeep's Avatar
blackjeep
Try lubing your cable.
Old Jan 12, 2020 | 09:38 AM
danny54's Avatar
danny54
My 09 was super light, My 2016 is a lot harder to pull, Its not your primary oil , Must be cable.
Old Jan 12, 2020 | 09:53 AM
sanman4ever's Avatar
sanman4ever
Use a silicon based lube
WJRenken
Jan 24, 2020 08:08 AM
Sibs
Custom Models
Jun 13, 2011 08:41 PM
Lou G
Mar 13, 2011 04:02 PM
CT-Bagger
Sep 25, 2010 06:01 AM
buick455gs
Oil Archive (no new posts)
13
Jan 23, 2008 08:17 AM
