Big Bore Clutch Recommendation
Old Feb 13, 2020 | 09:44 AM
hattitude's Avatar
hattitude
Originally Posted by HD Bobber
One thing i did want to add regarding clutch pull is that with the $450 performance clutch setups the pull is much easier with a higher pressure than using just a spring. I’ve had both and difference was night and day.
i forgot exact pressure specs on just the HD spring, but think it’s around 350lbs and once I upgraded my clutch/hub I setup the springs to 420lbs and pull was smoother and less effort than when I had just the spring.
Thanks for that info....
I have a 124" with an OEM with Barnett HD spring and AIM VPC... it's stiff...!! In stop & go traffic it gets old real fast...
I just put in a Muller secondary actuator and it helped it a lot...
But... I've been looking at some after market clutches. I've never used a performance clutch set-up, and wondered how they would affect the pull...
Old Feb 13, 2020 | 10:32 AM
skydude426's Avatar
skydude426
Originally Posted by Bafflingbs
AIM VPC will serve you very well, with the stock clutch basket. Easy install too.
This
miketv84
Jul 14, 2019 08:36 AM
kylebryan
Jun 13, 2015 09:00 PM
vtlkmonster
Jun 19, 2013 12:41 PM
BAMA_103RK
Oct 22, 2007 09:43 AM
motoxno53
Sep 25, 2007 11:54 AM
