Back wheel REALLY hard to turn when adjusting pushrods
Old Feb 15, 2020 | 07:59 AM
eighteight's Avatar
eighteight
[QUOTE=hepkat63;18877254]Could it be because the belt is a bit loose? wheel spins fine in neutral.
2nd statement rules out the belt
Old Feb 15, 2020 | 08:02 AM
Hoginedgewood's Avatar
Hoginedgewood
On Dawgs point, if you have an overdrive transmission 6 th gear would be bad. Go to the 1-1 ratio gear.
I usually find theres a little slack in the driveline, if im trying to spin clockwise I rotate ccw and then spin cw, little lunges
Old Feb 15, 2020 | 08:44 AM
skydude426's Avatar
skydude426
In 5th gear with the plugs out, it shouldn’t be difficult to turn. Especially with no pushrods installed as you aren’t even pushing against the force of the valve springs. I would be wondering if something isn’t right.
Old Feb 15, 2020 | 08:45 AM
Not2day's Avatar
Not2day
6th Gear
I wouldn't touch that starter switch, if your in 6th with the plugs out and can't move that rear wheel then something else is going on, maybe start over with adjusting the pushrod, I know this from wrecking a set on my old 99, luckily that's all could be worse.
Old Feb 15, 2020 | 09:27 AM
user 47363638's Avatar
user 47363638
Stock pistons?
Old Feb 15, 2020 | 09:42 AM
RANGER73's Avatar
RANGER73
I had he same problem, I used a whistler and a ziptie to get it to TDC so I could use both hands.
Old Feb 15, 2020 | 11:12 AM
ROCKOUT Rocker Products
Sponsor
They can be a bitch.... mine was.
Try rocking the back wheel...... rotate it backwards to take up any slop, then "knock" it forward against the resistance. It'll bump it around a little at a time. As mentioned above, I've used the starter for big movements then bumped it into final position.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 15, 2020 | 11:50 AM
hattitude's Avatar
hattitude
I put an SE big bore kit (95ci) in my 2003 Heritage about 4-6 months after I bought it new. The kit had SE203 cams and I believe was 10.5:1 pistons.
While upgrading cam tensioners, cam plate, breathers in the rocker boxes, and just to put new, shiny stuff in the engine, in the last 4 years I have been in the cam chest twice and messed with the rocker arms 4x
I remember the first time I tried to rotate the engine withe the rear wheel (5th gear/no plugs), I thought it was nearly impossible to do by hand... I had never done it before and didn't know what to expect... I could hear quite a hiss from the engine on the compression stroke, even with the plugs out... and the compression strokes were especially hard to rotate.
Now, I've done it numerous times. While I can't just spin it effortlessly with one hand, I can rotate it one handed, while watching either the pushrods or the pistons (I put a straw in the spark plug hole to watch piston height) for TDC.
It's a little strength, a little technique (rock the wheel), leverage (where/how to grab the wheel), and knowing what to expect.... but I wouldn't call it easy to spin...
As for the OP's bike.... without actually feeling how hard it is to turn, it would be hard to decide if something is amiss..... especially without knowing all the details of what has been touched/moved/handled in the process...
OP, I would proceed slowly, cautiously and replay every thing you've done in your mind, trying to remember things along the way that could lead to an issue.... eventually you'll need to spin the engine or disassemble it to see what's wrong (if anything)...
If this is your first time doing this, it might very well be the bike is OK, you just need to figure out how you need to position yourself, how to grab the wheel, and best technique to make it turn...
Good luck...
Old Feb 15, 2020 | 12:34 PM
IKnowNot's Avatar
IKnowNot
It is easier to turn it using hands then your foot.
Point was, if you can’t turn it with your hands, something is wrong.
When you are moving up the gears to put it in 6th, did you rock
the back wheel between shifts to make sure it is in that next gear?
Old Feb 15, 2020 | 12:43 PM
blap's Avatar
blap
Originally Posted by blap
Put in neutral, tap the starter then use the wheel for finer adjustment?
On second thought, don't.
