I hit a bump on interstate and the motor cut out. I didnt even notice at first bc the lights, accessories, and radio still worked. I coasted to the shoulder and turned it off and tried to fire it up. Nothing. Fuel pump doesnt prime and turn signals/hazards wont come come on. Red key light stays on now so Im guessing its an isssue with the security on the bike. Thought it mightve been BAS but I did the reset and still nothing. Ignition fuse was blown and was replaced. Still nothing. Looked over the bike and dont see anything out of the ordinary. Any suggestions?? The bike is a 2011 Road Glide
Not to be insulting .. but is the the off / run switch?
I did that when I first got my SG. Hit it by accident, coasted to the side of the road trying 3 or 4 times to start it with the clutch and down shifting. Once I realized what happened, I had just enough speed to give it one last go.
Yea I checked like 5 times to make sure it wasnt something stupid on my behalf. I put a clutch in it today, I couldnt imagine that would have done anything with it, but maybe so. I rode it around the neighborhood to make sure it was working properly and didnt have to be adjusted. Ended up having to get it towed back.
Sounds like Fujilicious might be on the right track with this one
I replaced the fuse and have the front fairing apart and put a meter on the ignition switch to make sure the switch worked. All was fine. As of now, turn signals, hazards, and fuel pump arent working. Could a security issue with the bike maybe cause this? I disconnected the battery and let it reset, and checked fuses/relays. The bike has V&H Fuelpak 3 fuel management on it. Could this cause a problem? Im lost.
Just a shot in the dark here , but I would check the battery cables for corrosion inside the casing , I've seen cables that look good and were damaged on the inside , hard to see .
Also check the ground connection on the post mounted to the frame just in front of the battery , on the right side , maybe one of them broke loose . Check and clean if necessary .
This could also be a crap shoot , but when was the last time you changed the battery in the FOB ?
