Axle nut??
Old Feb 23, 2020 | 10:32 AM
EVOrider's Avatar
EVOrider
Originally Posted by Andrewwayne
If you were that concerned about a critical component on a bike why not ask the owners or worker at the shop? That way if it wasn’t up to par they could address it or if it was normal explain it to you?
I wasn’t really concerned....the bike was still being worked on. It was just something that caught my eye.
Old Feb 23, 2020 | 10:38 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I was at a Indy shop I won’t mention....saw this
On a "normal" nut and bolt it is recognised that you need 1.5 turns of thread showing for maximum strength.
Looking at the axle nut you can see where the thread ends so it looks like the axle would finish about flush to achieve the 1.5 turns of thread.
The second picture by Boomer seems to confirm that.
EG-2006's Avatar
EG-2006
That whole 'drill bit' issue has changed over the years. On my '06EG the manual stated to use a drill bit in the holes and spread the fork tube until it makes contact with the bit, then tighten.
Different story on my '13EG. On the '13 the hole is there to hold the axle when tightening-so doing the 'drill bit' thingy on the '13 will screw up the alignment, brake caliper/rotor position, etc. Ask me how I know-go ahead, ask.
Old Feb 23, 2020 | 01:19 PM
skratch's Avatar
skratch
Originally Posted by internet troll
The factory manual literally states to use a 3/8ths drill bit....
on my 07 it did. but not on my 2010. so it 'literally' depends on what year you're working on.
Old Feb 23, 2020 | 03:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The factory manual says no such thing for a 2012 Touring Model.
Old Feb 23, 2020 | 03:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
It seems many people assume all Harleys are the same...
Old Feb 23, 2020 | 05:34 PM
multihdrdr's Avatar
multihdrdr
2000-07 1" axle - Use Drill bit Alignment Method
2008-later 25mm axle - DO NOT USE Drill bit Alignment Method (everything changed ... cross-drilled hole placement in axle, spacer lengths, etc)
Below pic for some Reference to differences (grabbed pic from one of my other threads)
08-later on Top ... disregard the bearing shim, that's used on 08-only from the factory (unless changing to wheels that need it)
Old Feb 23, 2020 | 06:30 PM
dawg's Avatar
dawg
The factory manual page reference 2012 touring front axle just happens to be posted in post #9
Old Feb 23, 2020 | 09:54 PM
internet troll's Avatar
internet troll
Well, once again it seems Im 20 years behind every service procedure. I was a service manager from 99-02....It would seem there have been a few changes since.
I owe Dan89 beer.
sweet07
Mar 10, 2020 02:01 PM
Chef 17
May 25, 2018 08:10 PM
cggorman
Apr 5, 2017 04:46 PM
DarkManC
Mar 5, 2014 08:31 PM
