Hi everyone, I have an 05 Injected Road King that I have owned since new, and have had very few issues with it until now. My speedometer started bouncing around, then just stayed on 0 all the time. I thought that maybe the speedo sensor was the problem. Nope, new sensor, still stuck on 0. Bought another sensor, still stuck on 0. Soooo, I guess it's not the sensor. Since I live in Florida, I know there's a lot of humidity and maybe moisture has gotten inside the speedo. Does anyone have any clues? Thanks for any help, Jim
Push and hold the reset button while turning ignition on. The older models would actually give speedometer codes and calibration number. Not sure if yours does this since Harley changed the speedometers in 2004.
Thanks, I'll try it next time I get a chance. Supposed to rain tomorrow.
When you do that it should also light all the lights on the speedo and the needle should make a full sweep. It's a diagnostic to determine if it is working. If it makes a full a sweep but doesn't work while riding, I would think loose/bad connection. Have you checked the plug under the speedo? A simple trick that works often on dirty plugs is to plug and unplug the connector a few times, then apply dielectric grease.
Good luck.
Hey Rd, thanks for those tips. I'll get right on it Bike Week is right around the corner.
So I went thru the diagnostic test and everything lit up , but the needle never moved. I did it again just to make sure, and the needle never moved. What does that mean?
Need more help.
If you have the electric speedometer (sounds like you do since you replaced the sensor a couple of times) it is really an electronic tachometer that counts pulses and displays the frequency as MPH. That the needle jumped around suggests some extra pulses from a poor connection and vibration causing extra pulses and then none. While it could eventually turn out to be an internal failure, checking all of the connections involved would be a good place to start. A service manual should have wiring diagrams and color coding of wires involved. If you can't find a bad connection or broken wire, the electrical manual may be required to go deeper. Many others have traced electrical problems, especially intermittent ones, to a fatigue failed wire inside the insulation in the vicinity of the steering head tube where all of the flexing from steering takes place.
Voltage fluctuation can cause a speedometer problem.
For example a bad regulator can cause an over voltage situation.
By chance are the 4 FOUR ends of your battery cables tight? each cable has two ends.
Has anybody tested voltage at battery..at rest, while cranking and at high idle?
Did someone jump start bike from a running vehicle just prior to start of problem?
Does the odometer show miles on bike?
Was the cable from speed sensor connection back towards the ECM reviewed for damage/broken wire?
Are you sure that speed sensor wires are in correct orientation at connector?
Was center console removed and flipped over to conduct a sniff test of speedometer ? Does the speedometer bottom smell like smoke?
Is the cable that plugs into back of speedometer tight? free of corrosion?
You stated "My speedometer started bouncing around, then just stayed on 0 all the time."
Does that mean it happened the ONE time and then stayed at zero or was problem ignored and repeated several times until the needle stuck at zero?
Friend of mine had the exact same issue , turns out there was a short in the connector at the back of the speedometer . As suggested , remove it and carefully check all the pins for corrosion . Sometimes the wires can break off inside the connector at the pin . There is a special tool , or a sharpened paper clip you can use to remove the pin , do one at a time , it will make it easier for you to check each one . I hope that's all it is .... and don't forget to disconnect your battery .
Need more help.
I checked and my 08 has a different part number than your 05 so I can't guarantee that the needle should sweep when running the diagnostic mode. Maybe someone with an 05 will chime in about theirs.
Does it add miles when you ride? If it does, my guess would be the servo that operates the needle in the speedometer has failed and you need a new speedometer. But don't go buy one on my advice. I'm often wrong
