2002 FLHTCUI ignition switch change procedure??
Old Mar 2, 2020 | 07:55 PM
joebedford's Avatar
joebedford
Default 2002 FLHTCUI ignition switch change procedure??
My switch suddenly started jamming - not just coming out of lock, but also from unlocked to ON and vice versa. After many wiggles, it will move as if nothing was wrong but clearly I can't trust it.
I'm away from home and my service manual is back home. Is the procedure online somewhere? I know there are videos for newer bikes but that doesn't help with a 2002 model.
Thanks, Joe
Old Mar 5, 2020 | 04:10 PM
joebedford's Avatar
joebedford
I managed to borrow a manual from someone and discovered that the switch had to be in the accessories position to be able to remove the lock.
The switch was loose and the tab on the shaft was not able to follow the groove in the collar. Cleaned everything and tightened it up and now it's fine.
dave713
Oct 29, 2016 09:44 PM
cmeans
EVO
Jun 13, 2011 10:36 PM
hdfatboy54
Mar 23, 2008 03:51 PM
rustyrun
Sep 3, 2007 06:30 PM
brocken
May 16, 2007 11:19 AM
