okay boys need aliitle help, installed aset of slipons on my EGS noticed it seems, itsrunning hotter than with the stock pipes. so what do i do? whats next,mine you money IS an issue best fix for least $ any suggestions bob
Rule of thumb: When you increase outflow (mufflers), you must also increase the air inflow (Stage I). Your bike is already set in a lean condition from the factory. Adding the pipes, you are now making the engine even leaner! Thus, more heat! This will in turn, lead to blue pipes, and lot of pings! You must richen your fuel/air mixture up! You'll find many threads on this forum about fuel management systems.
ORIGINAL: southerlytide
