So I recently put new bars on my 2011 HD street glide. Got it all back together earlier tonight, started it up, checked all my switches, Nice! everything works like it should... until I give it a rev and nothing. Where would you check first? Thanks Again!!!
Are you sure you reconnected the twist grip sensor? Its a separate 6 pin plug.
Else, the nonCVO bikes have an infamous green clip in line on the twist grip sensor wiring. They are known for breaking or coming apart while the wires are being ran thru the bars. Many either remove/solder those connections or replace the TGS with a CVO version which has no green clip.
