You absolutely do NOT want that "hot rod" cam in your stock engine. ( Do you WANT to pull the heads ? )
Nobody here is sure what started your project, Just a broken bolt ? Why did you open it up ?
Go to cam manufacturer websites and search for BOLT IN cams for baggers ( i.e. HEAVY bikes)
I`ll say it again Andrews EV 27 is proven in this application
I`m sure S&S and everyone under the sun has a comp.
Pick one and order it from Kirk or Revzilla etc so that you get what you order and not a "maybe" part.
JMO
I had an EV-27 in my 97 FLHTC. It runs good but has very steep lobe angles. It makes the valve train very noisy. Go to the EVO section and poke around. Those guys won’t bite.
