Trouble Updating GTS Infotainment System
Old Apr 10, 2020 | 03:44 AM
Peter_M's Avatar
Peter_M
Default Trouble Updating GTS Infotainment System
G'day,
My 2019 Road Glide Special had an outdated software version and so I thought I would download the new version (MY20.19.20.01) and upload it into my motorcycle.
I downloaded the file from the Harley Australia website, unzipped the folder and copied the contents onto a 3.0 USB flash drive that was just reformatted and empty.
I set my ignition to 'accessory mode' and plug the USB flash drive into my bike. The bike recognises the drive immediately and starts uploading packages 1 of 7. After it finishes uploading package 2 of 7, I see the following error message "Software installation processes was interrupted. Please leave ignition switch in accessory position and re-insert the USB device". I have attached some photos to see.
At this point, Im stuck. I tried different USB flash drives from 16GB capacity through to 128GB but none of these make a difference - I still see an error message after it finishes uploading package 2 of 7.
I am going to buy a 2.0 USB flash drive tomorrow to see if that works but if this fails, I am out of ideas.
Any advice from anyone who has experience with this issue would be greatly appreciated.
Cheers,
Peter
Old Apr 10, 2020 | 06:31 AM
Sam2010's Avatar
Sam2010
I do not know what the problem is.
My first thought is delete that copy of the download and re-download from HD site and try again.
Old Apr 10, 2020 | 06:00 PM
Peter_M's Avatar
Peter_M
Problem fixed!
There are different formatting option when formatting your USB flash drive in preparation to copying the unzipped files from your PC.
  1. I changed the formatting platform from the default "FAT32" to "exFAT". I note the operating manual states that either formatting option is acceptable but I guess different USB's are sensitive to which formatting option you use.
  2. proceeded to format the USB as "exFAT".
  3. copied the unzipped files onto the USB.
  4. removed USB from PC and plugged it into the motorcycle with the ignition set on accessory mode.
  5. Bike uploaded all files perfectly and fairly quickly.
See below screen shots. I hope this helps others.
Cheers
Peter
Old Aug 18, 2023 | 07:19 AM
Ricky Tan's Avatar
Ricky Tan
Stage III
Hi Peter.
But how do i press the RETRY button, even after i prepare the new USB drive which j have formatted to exFat.
Because the touchscreen doesn't work.
Old Aug 18, 2023 | 11:45 AM
M Oclaf's Avatar
M Oclaf
Originally Posted by Ricky Tan
Hi Peter.
Home button on left ???
Old Aug 18, 2023 | 12:21 PM
Ricky Tan's Avatar
Ricky Tan
Stage III
Hi Oclaf.
I appreciate your reply. However, i have tried that and it didn't respond. This screen basically unresponsive to any buttons i pressed.
HOWEVER, I FOUND THE SOLUTION (after reading more on this and other forums).
I RECOPIED the file to another USB drive. This time, i used a very old USB (from year 2010) yes, 13 years old USB. Definitely not USB 3.0. And i formatted it with ExFat format using windows.
It is still the same software file i downloaded earliwr
And this time, right after i went to accecory mode and plugged in the USB, the head unit showed: SOFTWARE UPDATE.
i officially exited the bricked state.
I felt 20kgs has been lifted off my shoulders. 😊😊😊
Hope my experience helps guys.
Thanks
Old May 18, 2026 | 01:07 AM
XTRMFLTRX's Avatar
XTRMFLTRX
1st Gear
Hi Peter.
Mine is doing the exact same thing now in 2026. Same year bike as yours too (2019). Nothing I try works.
marine778
Nov 5, 2018 12:16 PM
pomeara
Mar 20, 2017 10:54 AM
Ohio HD Guy
2014-2024 Touring Models
Feb 12, 2017 08:22 AM
tdkkart
13
Mar 3, 2016 09:33 AM
DaveNBPT
26
Dec 16, 2015 03:24 PM
