Software 1.20.3 Problem
Old Feb 11, 2017 | 10:01 AM
Ohio HD Guy's Avatar
Ohio HD Guy
Default Software 1.20.3 Problem
Just loaded the new 1.20.3 update on a thumb drive, the PROBLEM is I can't get the Boom system to to accept it to load it.
HELP
Old Feb 11, 2017 | 10:51 AM
timbo141's Avatar
timbo141
Are you following the instructions on the site? The unzipped file goes on the flash drive
SOFTWARE UPDATE INSTRUCTIONS
1. Verify your audio system’s current software version.
a. Select the following display menu items: “Home/Set-up/System Information Software Version”.
b. Record the software version.
c. Compare your audio system’s software version with the latest version available on this page.
d. If the software versions are the same, you have the latest software available and there is no need to update. If a higher level
software level is available on harley-davidson.com, continue to update your audio system.
NOTE: Do not interrupt the installation process. Leave the vehicle and radio turned on, and keep the USB flash drive installed until the installation process is complete.
2. Download the latest software version from harley-davidson.com
a. Select "Download Software Update" for the appropriate system.
b. When prompted, save the compressed file to your computer desktop.
c. When the download is complete, copy the file within the zipped folder to the root directory (the first or top most directory in a file system) of a USB flash drive that is 8 GB or larger.
d. Turn your vehicle's ignition switch to ACCESSORY. (Keyless ignition vehicles: press and hold the trip switch for more than two seconds).
e. Turn on the audio system and connect the USB flash drive to the audio system's USB port.
f. The audio system will detect the new software available and ask if you want to update. Select “Yes”. The display will prompt
you to remove the USB drive when the update is complete.
NOTE: If the incorrect software file for your audio system is copied to the USB flash drive, and connected to the audio system's USB port, the following error message will result: "The ISO image on the attached USB is corrupt or incompatible".
Old Feb 11, 2017 | 11:02 AM
Ohio HD Guy
Got it, finally.... It's been 6 months since I've done it
Old Feb 11, 2017 | 11:19 AM
timbo141's Avatar
timbo141
Cool, enjoy. Bike's numbers sounds like it is a fun bike to ride!
Old Feb 12, 2017 | 08:22 AM
Ohio HD Guy
Thanks, my Glide pulls like a bat out of hell!
Hedgehog
May 26, 2020 08:13 PM
pomeara
Mar 20, 2017 10:54 AM
tdkkart
2014-2024 Touring Models
13
Mar 3, 2016 09:33 AM
DaveNBPT
26
Dec 16, 2015 03:24 PM
mbranscum
Apr 23, 2015 11:12 PM
