2016 RG first ride impressions
The wife and I took a nice long easy ride yesterday afternoon on the new bike.
It ran fantastic but the front rotor is either warped or possibly contaminated in sections from sitting so long. It was extremely choppy when applying the front brakes. The front forks are also weak, not sure how much give to expect but the slightest touch of the front brake's sent the front end diving down.
The bitch is hot as you know what when it idles for any length of time.
The rear shocks bottomed out several times going over speed humps. My wife's a whopping 110 lbs so not sure what I need to do with them.
My biggest disappointment is in myself. After years of body building and having a grip of steel, I now have arthritis in my hands and was in actual pain after 30 mins of riding. Its been creeping up on me over the years and I'm only 52 yrs old. Hopefully with more seat time it will pass. Anyone else have this issue?
Safe riding
Tim
1. Seat?
2. Bars
3. header pipe and slip ons
4. Get it dyno tuned
Getting rid of the cat in the header will get rid of some of the heat. Getting it tuned at the same time will do wonders in how it runs and the heat
- The brake fluid needs to be replaced, should be replaced every 2 years. I know the bike is low mileage but have the system flushed
- Have a dealer check the rotors and pads
- I can’t remember if the rear shocks are air or hand adjustable. Either way make sure they are set for the correct weight when riding
- Like mentioned above a cat less header and tune will reduce the heat. Harley also makes a cool-flow fan for the pre ‘17 touring models. This pulls the heat down and away from the rider/passenger when setting still or in slow traffic
- Correct windshield can reduce stress on the neck, chest and arms
- Seat that is comfortable and allows for good control of the bike
- Highway pegs so you can change your riding position taking pressure off your back, legs and arms
- i have the same issues with my hands and elbows. For me it was getting the correct bars, I used 12” Factory 47 bars on my RG, 10” Wild Ones on my batwing bikes. Then just riding to get my arms used to it. Also when possible I use cruise control, always ensuing a comfortable amount of pressure on the grips. Since you have not been riding much recently you might have a tendency to grip to tightly causing the pain. I grip to tightly if I’m riding a lot of curves and switchbacks and my hands cramp in a matter of minutes. I’ve ridden in the mountains at a fairly fast pace for about 45 minutes to an hour. When I get off the bike I can barley keep my hands open, they were gripping so tight. For me it was something I had to work on. I stated working construction at the age of 14 and had a pretty physical job until my early 40s. This along with sports and weightlifting took a toll on my body, I’m now 53.
- I cant remember if the rear shocks are air or hand adjustable. Either way make sure they are set for the correct weight when riding
- Like mentioned above a cat less header and tune will reduce the heat. Harley also makes a cool-flow fan for the pre 17 touring models. This pulls the heat down and away from the rider/passenger when setting still or in slow traffic
- i have the same issues with my hands and elbows. For me it was getting the correct bars, I used 12 Factory 47 bars on my RG, 10 Wild Ones on my batwing bikes. Then just riding to get my arms used to it. Also when possible I use cruise control, always ensuing a comfortable amount of pressure on the grips. Since you have not been riding much recently you might have a tendency to grip to tightly causing the pain. I grip to tightly if Im riding a lot of curves and switchbacks and my hands cramp in a matter of minutes. Ive ridden in the mountains at a fairly fast pace for about 45 minutes to an hour. When I get off the bike I can barley keep my hands open, they were gripping so tight. For me it was something I had to work on. I stated working construction at the age of 14 and had a pretty physical job until my early 40s. This along with sports and weightlifting took a toll on my body, Im now 53.
