Tpms
Old Apr 16, 2020 | 12:45 AM
UrbanRunner's Avatar
UrbanRunner
Default Tpms
My rear TPMS reads 9 psi high compared to a direct reading (with multiple different tire gauges). Is there a way to adjust this or is it the same accuracy as the fuel gauges?
Old Apr 16, 2020 | 04:37 AM
Keithhu's Avatar
Keithhu
Could be faulty, I've never had a problem. Also it takes some tune to read if you're not riding. Take it for a spin and see what you get.
Old Apr 16, 2020 | 04:50 AM
kojak's Avatar
kojak
Mine is pretty right on at cold temp. Never check my tire pressure after the tires are warmed up.
Old Apr 16, 2020 | 09:02 AM
barneyboy's Avatar
barneyboy
If you suspect a faulty sensor, a dealer can use their TPMS activation tool to force a data update once the pressure has been properly adjusted using a verified accurate tire pressure gauge.
File Type: pdf
rvkersh
Mar 29, 2017 11:19 PM
roadkingdoc
2014-2024 Touring Models
Apr 14, 2014 06:10 AM
Rat1
Apr 25, 2011 07:15 PM
asherdav
Feb 20, 2010 09:08 AM
campdreamer47
Sep 4, 2007 06:45 PM
