Roadglide Shocks
Old Apr 17, 2020 | 07:51 AM
user 47363638's Avatar
user 47363638
Default Roadglide Shocks
I have a 2019 Roadglide, 107, I’m sure this has been beat to death, I don’t care I’m self locked up and bored, as are a couple of youse. What size are the stock shocks and what is a good alternative, I would like to drop it about 1/2-1 inch.
Old Apr 17, 2020 | 08:05 AM
Red's Avatar
Red
Rg 12"
rgs 12"
rgu 13"
Old Apr 17, 2020 | 08:06 AM
skratch's Avatar
skratch
if its just the roadglide and not the ultra, then the stock shocks are 12''. any of the name brand shocks, legends, supershox, pro-action, ohlins, etc. will give you a better ride. and with the sag set properly, give you that 1/2'' drop. but for an even better ride, go with the name brands in a 13'' version. with the sag set properly, you'll sit at about the same height as you do with the stock hd 12'', but the ride will be much improved.
Old Apr 17, 2020 | 09:39 AM
DHS-Officer's Avatar
DHS-Officer
I purchased a set of 13" Progressive suspensions coil overs. set about 3/4 in of droop in them and the ride is AMAZING.
Progressive Suspensions
Click the link. They have a full line of Harley specific shocks
Old Apr 17, 2020 | 11:32 AM
19special's Avatar
19special
Anybody that had 12 from factory and switch to 13 do anything to the front?
Old Apr 17, 2020 | 05:33 PM
Dynamick's Avatar
Dynamick
I didn't, because as stated once you have the sag set correctly with a 13" shock your actual ride height doesn't change that much.
Old Apr 17, 2020 | 08:05 PM
skratch's Avatar
skratch
you don't need to. the front is the same as the stock ultra with 13'' shocks. they didn't change the geometry any when they went to the 12'' shocks. the only exception to that is with the 'low' models, which they've phased out anyways.
pyuchem
Mar 13, 2020 02:36 PM
mstrlucky74
Mar 26, 2019 07:50 PM
Temporary Username 1
Oct 9, 2014 07:39 AM
mrfikser
Feb 7, 2013 05:35 PM
OkieLongHair
Apr 23, 2012 03:47 PM
