2009 Frame upgrade question
Old Apr 22, 2020 | 02:19 PM
skratch's Avatar
skratch
Originally Posted by handirifle
Funny all the different numbers. The HD website for 2020 Ultras says 94" even. So it SOUNDS like, after reading the article, that the engine compartment was shortened (my guessing) allowing the swingarm to be lengthened without changing the overall wheelbase much, (1/2").
What size are the old rear tires? New is said to be 180.
in 2009, hd went with the 180 rear tire. wheelbase in 08 was 63.5''. in 09 was 63.5'', and remained so until the rushmore in 14 where it became 64.
Old Apr 22, 2020 | 03:51 PM
Dynamick's Avatar
Dynamick
Rear tire spec was MU85-B16, which has a width of 140 mm
Old Apr 22, 2020 | 04:36 PM
handirifle's Avatar
handirifle
Ok wow small for that heavy a bike
Old Apr 22, 2020 | 10:51 PM
multihdrdr's Avatar
multihdrdr
Both the Touring's MU85 (140) and the MT90 (130 used up to 2003) have a higher Load Rating than your Sporty's 150
Old Apr 22, 2020 | 11:04 PM
handirifle's Avatar
handirifle
But still a smaller contact patch.
Old Apr 22, 2020 | 11:12 PM
multihdrdr's Avatar
multihdrdr
"Ok wow small for that heavy a bike"
Higher Load Rating is what matters ...
Sporty's also didn't use anything wider than a 130 until 2004 (just like the Touring), but they are different tires ... guess what's different ... Yep, Load Rating
Old Apr 23, 2020 | 11:26 AM
grbrown's Avatar
grbrown
Wink
I doubt it. After jimglassford's post I looked and 2007, 2009, and 2011 all show 63.5" wheelbase. So does the 2014. So what lengthened? I get the larger tank, is the tank wider, or longer or taller, or all the above?
I bought a 2009 tank and installed it on my 1990 Evo Glide. Initially I couldn't make out where they found the 'extra' gallon, which I discovered is almost exactly a 6" cube. So where did they hide that extra capacity? Compared with my stock 5 gallon tank, the front of the bigger tank is a little further forward on the frame of my bike, and overall the tank is about 1 1/2" longer. In addition the top surface of the tank is bowed upwards more than the old tank and the underside of the tank has fewer cutaways. So most of the extra capacity comes from three main changes: bottom, top and length of the new tank. Measuring rounded things isn't easy, but overall width seems unchanged.
Hope that helps!
Old Apr 23, 2020 | 11:35 AM
grbrown's Avatar
grbrown
Cool
Harley used the same size tyres from way back on their big twins. They went a little wider with the rear tyre on the twincams, as multihdrdr has pointed out, but all on the same width rims. The first change in wheel/tyre sizes in decades came in 2009. The front tyre was always fine, the concern was with the rear tyres, which with Mrs B and I plus the kitchen sink was always on the limit IMHO. I have rectified that in part by upgrading to a Deuce rear wheel and a 160 wide tyre with bigger load rating.
If you choose 2009 or later bike you can set aside such anxieties!
Old Apr 23, 2020 | 11:54 AM
handirifle's Avatar
handirifle
GR you are the one I figured would know, since you had mentioned the swap you did. Still on the fence with that bike, or just being patient for an '09 or later. I just since riding that one noticed the exhaust running down by the pass floor board. The wife would not appreciate the heat, since she is pretty heat sensitive anyway. And looking at the '08s they have an even funkier exhaust, that does a U turn to the left side. Not sure if that is much better. SO in '09 they decided to give all the exhaust heat to the rider, LOL.
Still looking. Nary a nibble on the sporty, which does not surprise me, no biggie will gradually lower the price till I get bites, or remove it.
Old Apr 23, 2020 | 01:42 PM
jimglassford's Avatar
jimglassford
I am not sure how contact patch has changed by going to a wider tire. I remember years ago, I read an article on the Corvette and wider tires for improved handling. The results were that as long as the vehicle weight is the same and tire pressures are the same, the contact patch is the same no mater the tire width. The benefit was in how the side wall reacted in turns. A car tire is more of a rolling cylinder where the motorcycle is curved in two dimensions so it can lean but wouldn't the physics be the same?
I mean, to make it simple, if a motorcycle had a weight of 1000 pounds and and each tire had 100 psi, the combined contact patch is 10 square inches. Reducing tire pressure results in a larger contact patch.
I am not stating fact here, it is a question to think about.
