Front motor mount replacement
Old Apr 27, 2020 | 01:59 PM
hdrider98ci's Avatar
hdrider98ci
Default Front motor mount replacement
I have a 2015 road glide 58k , thinking its time to replace the front motor mounts . I don't see a lot of aftermarket replacement options . Are the stock HD ones the best to use or are there better ones available ?
Thanks
Old Apr 30, 2020 | 10:19 AM
Whodeynate's Avatar
Whodeynate
When I replaced mine on my 96 RK I did some research and found the best option for me was the OEM mount since it was rubber and a little softer than the after market polyurethane styles. The poly's do last longer and are stiffer but since I have an Evo, that we all shakes fillings out of teeth lol, I was fearful that my crossover pile would crack with the poly. JP cycles and Dennis kirk both have a decent selection of them. Lots of good reviews about them but like I said I felt it would work for me. Hope this helps a little bit.
Old Apr 30, 2020 | 10:30 AM
Inop's Avatar
Inop
If you do a search for front engine motor mount you will find that a lot of guys are running the Glide Pro motor mount. I bought one but have not installed.
Old Apr 30, 2020 | 12:57 PM
fordhd2005's Avatar
fordhd2005
I went the expensive aftermarket route and really regretted it. You will feel every vibration (or at least I did) and ended up replacing both inner fairing brackets after about 1000 miles. After about 3000 miles it seemed to settle in. I also did the swing arm bushings at the same time. That was a good upgrade. But I would go stock on the motor mounts if and when I replace them again.
Old May 1, 2020 | 07:15 AM
Tarkus60's Avatar
Tarkus60
I used the glide pro and I think its a bit smoother. Is night and day difference ? No.
I hoping it will last longer. Would I purchase it again? Yes
Old May 1, 2020 | 07:25 AM
eighteight's Avatar
eighteight
Since you got 58K from the OE unit, I`d buy another.
Old May 1, 2020 | 07:36 AM
grbrown's Avatar
grbrown
The 1996 and 2015 bikes referred to use quite different front rubber mount systems, so there is no comparison. On the earlier bikes a direct replacement is perfectly satisfactory, quite probably the same for the later models.
Old May 1, 2020 | 08:41 AM
Whodeynate's Avatar
Whodeynate
grbrown,
I should have put that in my reply. Thanks for catching that and hopefully I didn't cause and confusion on using my example when I needed mine replaced.
greggmig
May 26, 2020 10:37 AM
D W K
May 25, 2020 07:12 PM
robvg
Sep 4, 2019 11:42 AM
MIKE93SVT
EVO
Jan 15, 2015 07:02 AM
blockheadcase
Feb 15, 2012 05:01 PM
