Blowing a fuse repeatedly
Old May 1, 2020 | 12:51 PM
Redbeard719's Avatar
Redbeard719
From what I can read in the pictures, it looks like this wire/circuit your chasing also involves the front fender tip light. Check that wiring in/under the front fender.
I've seen it before where that wire was chaffed/exposed and causing the same issues you're describing.
Old May 1, 2020 | 02:04 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'm on the harness under the rear fender wagon, but would also check the rear running light/brake light for corrosion in the socket or on the bulb contacts that may be going between the contact points.
Old May 2, 2020 | 07:10 AM
WISnowman's Avatar
WISnowman
Stage IV
Thumbs up
Originally Posted by IKnowNot
Your signals do not get power from that fuse, the front running light in the lamps get power from that fuse.
You did not say if it was intermittent or a dead short.
If it is intermittent first check to see if any lights aren’t working when fuse is good, then you are going to have to go around inspecting and shaking all the associated wires to see what wire blows the fuse.
If it is a dead short I would start by finding out if it is in rear, front, or other.
Unplug the rear lights (plug 7 A/B) and Tour-Pak (plug 12 A/B).
You can either check the wires from the plugs for shorts with a VOM, or just put in a new fuse and see if it blows.
If no luck there, unplug the interconnect harness (plug 15 A/B) then Fender Tip Lamp (can’t read it, but believe it is plug 32 A/B.)
If your bike is the same as mine, locations are as follows:
7 A/B under seat (then goes to underside of rear fender, might look where it goes through fender)
12 A/B inside Tour-Pak
15 A/B inside fairing, right side by radio brace
32 A/B inside fairing, left side bottom near lowest fairing screw (follow up from front fender)
Good luck, let us know how it turns out.
Thank you so much! Is there an easy way to check under the fender? It is so close I can't get up in there. I have bigger arms. What should it feel like?
I will start trying to eliminate what is causing it by disconnecting plugs.
Thank you again!
Old May 2, 2020 | 07:48 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Disconnect the plug for that rear harness, turn on the ignition, if the fuse does not blow, you have most likely found the problem area.
Old May 2, 2020 | 07:53 AM
WISnowman's Avatar
WISnowman
Stage IV
Will give that a try!
Old May 2, 2020 | 08:00 AM
Jackie Paper's Avatar
Jackie Paper
Thank you again!
If the problem goes away when you unplug that rear harness under the seat, the rear tire will need to be taken off if it's not in the light assembles.
Years ago I had a dead short in the rear. The wires with the contacts for the bulb came thru a small plastic disk. It had split allowing the spring load hot wire to get over to ground.
Of course it and buried inside the signal light/tail light. Had to look at ever inch of wire to figure that one out.
Old May 5, 2020 | 11:25 AM
WISnowman's Avatar
WISnowman
Stage IV
Ok, I think I have narrowed it down to somewhere in the main connector inside the bag to somewhere back to the fuse block. I will see if there is another connector somewhere else that is in between.
Shane T
Nov 6, 2024 09:32 PM
Mel B
May 2, 2020 08:22 AM
Ink191919
Touring Parts
Sep 28, 2019 12:28 PM
edge540steve
Jul 11, 2012 12:35 AM
RoadShark
Mar 3, 2010 06:15 PM
