whining noise when shifting
Old May 4, 2020 | 05:18 PM
Booyar1967's Avatar
Booyar1967
Stage III
Default whining noise when shifting
I have a 2013 Street glide and this weekend going on a cruise I noticed a whining noise as I was shifting and accelerating. once I decelerated it would stop and upon accelerating it would continue. Once I was in 6th gear it went away. but going threw the gears it would get louder. Any suggestions? Thanks!
Old May 4, 2020 | 05:31 PM
thedoctor77's Avatar
thedoctor77
Yore post #1!
Welcome to the party!
I hope you get some reasonable answers. Mine isn't.
Get a louder exhaust!
On the serious side it sounds like a bearing within the transmission. A bearing that's not used for 6th gear if that's possible. You've had this bike for awhile and this is a new noise?
Doc
Old May 4, 2020 | 05:36 PM
Booyar1967's Avatar
Booyar1967
Stage III
Yes! I never noticed it before. When I accelerate it would make the noise. If I release the throttle it would stop. And as I mentioned going in to 6th gear no noise.
Old May 4, 2020 | 06:05 PM
btsom's Avatar
btsom
I have had something similar and traced it to the belt, believe it or not. A little silicone spray on the belt and it would stop....for awhile, then return. loosened the belt tension slightly and it want away permanently. The "whine" could in reality be a belt squeak only when the belt is pulling hard, not enough torque in 6th to make the belt pull that hard. At least you don't have to take anything apart (except remove a saddle bag) to spray the belt. Give that a try before getting out your set of tools.
Old May 5, 2020 | 06:41 AM
Tarkus60's Avatar
Tarkus60
I agree look at your belt. Check your tension.
Old May 5, 2020 | 12:03 PM
Booyar1967's Avatar
Booyar1967
Stage III
Smile
Thanks btsom! I will try that. I appreciate the feed back. Take care!!
Old May 5, 2020 | 12:49 PM
rozemab's Avatar
rozemab
Usually when I hear a whining while accelerating, it's my wife behind me.
Anthony Grassi
Welcome Area Only
23
Mar 15, 2020 12:27 PM
TheSter
May 28, 2012 11:01 AM
HardyHarHarley
May 17, 2009 10:53 PM
Pythagrean
Aug 15, 2008 06:47 PM
deadbug
Apr 20, 2008 09:08 AM
