air cleaner comparison
Old May 2, 2020 | 01:32 PM
metalcruncher's Avatar
metalcruncher
Default air cleaner comparison
From page 417 of the 2020 HD parts and accessories catalog:
I’m looking at upgrading my air cleaner, along with slip ons and the HD pro street tuner. My 2020 Road Glide Special comes with the wedge type air cleaner. I prefer the look of the round style like I had on my Road King.
Screaming Eagle has four options: heavy breather, ventilator, round and wedge.
I find it interesting that from the above 114CI stage upgrade charts, different air cleaners are used. I assumed (probably wrongly) that one model would be the “best” for all stage upgrades.
HD uses round for stage 1, heavy breather and wedge (torque or power cam) for stage 2, heavy breather for stage 3 and ventilator for stage 4.
I plan on stage 1 with a tuner and, maybe later, a stage 2 torque cam. For discussion purpose, if I upgrade to the extreme flow-round air cleaner, should that provide sufficient airflow to support a stage 2 upgrade or is the heavy breather (from above chart) the correct choice?
Old May 2, 2020 | 01:57 PM
Kawickrice's Avatar
Kawickrice
Any will work with just slipons. Unless you build a big CI motor you are worrying about nothing jmo
Old May 2, 2020 | 03:22 PM
hattitude's Avatar
hattitude
As long as the air cleaner flows enough air for your application.... the style, looks, size won't matter..
For example, the stock Rushmore air filter is thought to flow about 175CFM... If your engine needs 160CFM at max flow, then changing that air filter to one that flows 200CFM really won't make a difference...
If your engine needs 200cfm... using an air filter that supplies 220, 240, or 250cfm will all supply enough air. One won't provide better performance than another.....
The air flow of an engine is determined by rpm, VE (volumetric efficiency), and displacement..
I checked my notes (thanks to mkguitar on this forum) and CFM = cubic inch displacement x RPM x VE /3456
Volumetric efficiency varies with RPM. If I remember correctly, VE is at it's max, when the torque peaks, then decreases from there... but I couldn't find that in my notes to confirm it...
Old May 2, 2020 | 05:20 PM
decencyxdefied's Avatar
decencyxdefied
I was expecting this to be an actual intake cleaner thread lol
Old May 5, 2020 | 10:40 AM
metalcruncher
It would be helpful if Harley Davidson published the CFM flow ability for each air cleaner in the catalog or on the HD parts website.
I've gone through as many threads on this and other forums to find physical numbers or dyno results. Lot of opinions, not a lot of data.
For instance, from the parts catalog, the round high flow air cleaner flows "more" air than the stock round filter. And the round extreme flow air cleaner flows 11% more than the high flow which flows "more" than the stock.
I'm only going as high as Stage 2 so I've made my choice based on favorite looks and we'll see what the Pro street tuner can do to the performance.
Old May 5, 2020 | 02:27 PM
BigDogIdaho's Avatar
BigDogIdaho
I'm not an expert but....😆
Any intake set up will do for 95% of the applications.
You can go with whatever one you like the looks of the best.
kds454
Jun 6, 2014 12:36 AM
zabijaka
Aug 9, 2012 01:09 PM
Non11
Jun 6, 2011 03:37 AM
J-Train
Mar 23, 2010 01:57 PM
ecoli
Oct 8, 2009 03:18 PM
