Decisions Decisions
Old May 3, 2020 | 06:34 AM
Patrick Knowlton's Avatar
Patrick Knowlton
6th Gear
Default Decisions Decisions
I have a 2003 EGS (Police) that I bought a little over a year ago. I've been staring at it for months now and making small changes/upgrades. I took it for a long ride yesterday and can hear what sounds like some valve train noise in the top end. Doesn't sound too serious. Nothing super crazy, just a little noisier than usual. It has a couple of leaks here or there. Nothing too ridiculous. I know very little about the bike as far as what motor work has been done to it. The VINs match so its the original bottom end, at least, but I know nothing about cams or top end work that may have been done. This is the first Harley I've ever done any real work on so, I don't know a ton about Harley motors, but I am a motor guy (hot rods and crawlers). I does have an old PCIII on it.
My questions are....
1. Is it time for a rebuild? (65,000 miles on it, but it may have been rebuilt already)
2. Or, does it just need some rocker adjustment?
3. This motor came with both FI and carb... can I switch it over to carb and get that old school sound without risking too little oil flow?
4. If it is time for a rebuild, I think I'd like to make it a beast. Cams, new exhaust, new fuel tuner, etc. What are your recommendations? I generally ride this one alone, although, the wife will join me on occasion. She prefers the EGC. I like to cruise it around 55-65, but I want it to move out when I twist the bars and I want it to sound like it will eat your first born.
5. What should I expect to pay for this kind of work? (Would it be a better idea to buy another motor with this work already done and do the swap myself?)
What are your thoughts?
Attached Thumbnails Decisions Decisions-94468066_10213708269379539_5399008185832964096_n.jpg   Decisions Decisions-94624603_10213708268099507_6140748393607069696_n.jpg
Old May 3, 2020 | 07:10 AM
user 47363638's Avatar
user 47363638
Plenty of options and it all depends on your budget, I just put a bunch of money into my bike with no regrets, I bought it new and wanted to keep the original engine, sometimes I wish I would’ve just went with a new S&S engine, it would not have cost that much more. I have no advice except spend the money once and do it right. Nice looking bike too.
Old May 3, 2020 | 07:50 AM
Geoff1200's Avatar
Geoff1200
Air cooled V twins are inherently noisy. 03 efi is the first year Delfi, a good system, as far as the old potato-potato- potato idle, you will have to ditch efi / electronic ignition etc... what you will gain is a less reliable bike that won't last very long before it needs a new lowerend. Your call
Old May 3, 2020 | 08:18 AM
EG-2006's Avatar
EG-2006
That motor has hydraulic lifters so there are no rocker adjustments that can be made-unless motor work has already been done and an adjustable pushrod has come loose. Those top ends are noisy even when everything is right.
I would first recommend that you pull off the cam cover and check the cam chain tensioner shoes. They are a well known weak point. And if it has an aftermarket cam plate then you know work has been done on it.
For a total rebuild, Fuelmoto has a 98" kit that I was looking at when I had my twin cam. Very tempting.
Old May 3, 2020 | 09:10 AM
hattitude's Avatar
hattitude
Do you know if the engine is OEM, or if their have been mods/upgrades done to it...???
Do you have the tools to do a leak-down test to check how tight the engine is at 65K miles... That could give a hint to any issues, or potential issues...
As mentioned... on that year twin cam bike (up to 2007) the spring cam tensioners are a weak spot... At 65,000 miles, if they haven't been changed, you are on borrowed time.....
Open the cam chest and check the tensioners.... It should also be a clue if any work has been done... If everything is OEM...
1) Replace the cam tensioners (many options from $ to $$$$),, search this forum, you will have a bunch of reading for cam tensioner replacements
2) While in the cam chest, change the inner cam bearings from the INA Brand caged bearings to the Koyo-Torrington captive needle bearings..
3) While you have the better HD lifters.... they have 65K miles on them.... replace them with a good aftermarket lifter (I use Johnson-Hylift from WFO Larry at Larry's motor machine online)
You might also remove the rocker box covers and inspect the rocker arms... check the tolerances, maybe add Rockouts (search there is plenty of info), and upgrade to the better, stamped style breather assemblies....
Many of these things MAY have been addressed on that bike due to it's mileage... if not, they are overdue...
Old May 3, 2020 | 11:44 AM
ROCKOUT Rocker Products
Sponsor
Have a look around my website, might be just what you need... thousands of happy Rockout customers
Also try changing oil. When it comes to noise, there is nothing better than Spectro 25-60 NON-SYNTHETIC.
Good luck in the hunt!
John @ Rockout
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old May 3, 2020 | 08:40 PM
23Seven's Avatar
23Seven
Do not ditch the EFI just to have a cooler sounding idle. EFI is way better than carb.
04NightSpider#47/50
Engine Mechanical Topics
May 8, 2018 08:43 PM
WindowMan
EVO
19
Jul 16, 2017 07:58 PM
Wcm71
Ironhead
May 15, 2014 10:33 AM
sloroller
Exhaust System Topics
Oct 11, 2011 07:26 PM
