Ironhead A place to talk about Ironheads.
78 Ironhead on rigged
Old May 13, 2014 | 09:30 AM
Wcm71's Avatar
Wcm71
Default 78 Ironhead on rigged
Hey guys i just got my first Harley it only took 43 years . I have to say Im very happy its on a rigged frame but the ride isnt that bad.
I only have a few things that I issues with I hope yall can help. The first thing is sounds like a hollow tapping coming from the front end of the the motor. 2nd is back firing out the crab while riding it has a super B crab on it. Any ideas are appreciated.
Old May 13, 2014 | 01:34 PM
IronMick's Avatar
IronMick
One common cause for backfire out the carb is a lean fuel mixture, which could be caused by jetting in the carb or by an air leak among the air cleaner, carb, and manifold.
I have not had a,S&S carb, nor have i had this problem myself so i'll leave it to others to be more specific about possible solutions.
Some notes for the tapping sound ...
The "sound" can be quite disturbing, very much like the engine is going to blow up. Literally like a tin can of marbles. What you need to do is to determine if it is the normal sound or if something is wrong.
The best way to do this is to listen with a mechanics stethoscope. You can use a screwdriver or a length of hose but the real tool is much better, and can be purchased inexpensively at Princess Auto or Harbor Freight.
With the engine at idle listen at ...
  • all 4 rocker ends, both sides of the engine
  • all 4 pushrods, top, middle and bottom
  • all 4 lifter blocks
  • all 4 cams, listening thru the gearcase cover
  • both ends of the generator
All similar points should sound about the same, like rotating steel parts. The generator should be 2 or 3 times noisier than the other points.
If a pushrod is too loose you will hear a louder click sound at its lifter block.
It is worthwhile to do this process a couple of times a year, just to keep track of stuff. It is a very good idea to do this when the engine is running well so that you know what running well sounds like thru the stethoscope.
Old May 14, 2014 | 09:52 AM
Wcm71's Avatar
Wcm71
Thanks Mick I found the source of the noise it was the pushrods.
Old May 14, 2014 | 11:44 AM
IronMick's Avatar
IronMick
If they are quiet they are too tight. You should be able to hear the clickety clackity. Listen to this, especially when the camera is close to the engine, on both sides. The sound of a well tuned, good running IronHead with properly adjusted push rods ....
Old May 14, 2014 | 03:07 PM
Wcm71's Avatar
Wcm71
wow very nice Im working right now but I will try to send a video tomorrow or tonight if I I can send from my phone. I still have some work to do on it as far as Paint goes but that will have to wait a few months Im having to much fun at the moment .
Old May 15, 2014 | 10:33 AM
Wcm71's Avatar
Wcm71
Default Link to my ironhead
Hey Mick here's the link to my bike. http://youtu.be/wG_7LJbuQJ0[/URL]http://youtu.be/wG_7LJbuQJ0
FlyBD5
EVO
11
Aug 19, 2012 07:26 PM
Krazyshark
Ironhead
Jan 23, 2012 07:51 PM
dlnp22
Aug 10, 2009 01:24 PM
99Sportster
Aug 29, 2008 06:53 PM
95fatty
Exhaust System Topics
Jan 16, 2007 03:02 PM
