Engine Noise Concerns
Old Aug 28, 2008 | 10:17 PM
99Sportster's Avatar
99Sportster
Default Engine Noise Concerns
I know its difficult to diagnose over a forum but here it goes...
Today I noticed in gears 1,2 and 3 while at high rpm's, I hear a slight hissing sound kick in as though the carb opens all the way up. I normally don't get it up in high rpm's but it happened while getting out of a traffic jam...had to make a fast exit off to the shoulder to
avoid a wreck and throttled it pretty high.
Performance appears to be the same and the plugs looked normal. I changed them out anyway and still hear the hiss sound.
When I got home I let the bike idle while on the stand and got close to the lower case below the heads. I didn't hear any knocking or grinding sound but I do hear a type of rotary sound. Either that's new or I just never heard it before, maybe my ears are just playing tricks on me? But I do know for a fact the hissing sound is new.
Ideas?
Old Aug 28, 2008 | 10:24 PM
JosephGarcia's Avatar
JosephGarcia
airleak, check the seal from the AC to the carb body, or carb to manifold.
You have air rushing into OR out of a small space at a high speed, thats the hissing noise.
and the speed or RPM doesnt matter so much, they just happen to be the frequency at which the airleak becomes obvious to your ears, its still there all the time though. Like how a whistle only works if you blow through it fast enough.
hopefully you just need to tighten a loose bolt or replace a worn gasket. no big deal. update on what you find what you do some poking around.
Old Aug 29, 2008 | 10:42 AM
99Sportster
Thank you Sir. I will certainly try that this evening and repost my results.
Old Aug 29, 2008 | 03:35 PM
Sick1200's Avatar
Sick1200
While it is definitely a good idea to check what Joseph had to say, my guess is, since there was no change in performance and you don't get up in the rpms that much you're just not used to the sounds. As far as the rotary sound your hearing, it's just the valvetrain doin it's thang, sporty's are a very loud motor.
Old Aug 29, 2008 | 04:25 PM
JosephGarcia
maybe its normal in high RPM for the new evo sporties becuase of the way the AC is designed.. but I dont hear it on mine.
on my ducati though.. wow.. LOUD swoosh of air from the huge airbox that is directly under the gas tank. its cool when all the harmonics mix at the right freguencies and it turns into a nice hum, a very musical tone.
Old Aug 29, 2008 | 06:53 PM
Zimbob's Avatar
Zimbob
Normal for an evo, sportster or otherwise. All you heard was the motor sucking air. The rest is just the internals doing what they do. If there was an air leak, it would pop and generally run like crap.
Ert
Milwaukee Eight (M8)
Dec 11, 2018 04:29 PM
Snedigity
May 17, 2014 12:15 PM
Wcm71
Ironhead
May 15, 2014 10:33 AM
dlnp22
Aug 10, 2009 01:24 PM
ATM67
Shovelhead
Aug 30, 2007 07:33 PM
