Hydraulic clutch cable replacement
Old May 8, 2020 | 05:53 PM
Performancebagger22's Avatar
Performancebagger22
Stage II
Default Hydraulic clutch cable replacement
I just put a new bar setup on my 2017 road glide and the clutch cable is tight. I have never changed one of these hydraulic cables before and cant seem to find any videos on it. Is it as simple as bleeding the line, unscrewing the hold hydraulic cable from the slave cylinder and replacing with the new cable and adding new fluid and bleeding. Just cant believe that it is that simple. Anyone done this before. Any help would be appreciated.
Old May 8, 2020 | 05:59 PM
dawg's Avatar
dawg
Pretty much. It’s just like a brake line. Replace, bleed. I did one when I put apes on a bud’s 16 street glide.
Old May 8, 2020 | 06:02 PM
Performancebagger22
Stage II
awesome thanks, I just did the krause isolated pull back riser set up and the pull back is the problem. If I went with the straight risers I dont think it would have been a problem to leave the stock cable. Thanks for the help.
Ratherberacin
Mar 23, 2016 08:17 PM
rquest
Nov 30, 2012 05:36 PM
rancid13
Oct 5, 2012 09:24 AM
08 glide
Apr 17, 2011 04:45 PM
Jukebox
Feb 26, 2010 12:44 AM
