Radio Problems
Old May 13, 2020 | 01:11 PM
The Nev's Avatar
The Nev
Default Radio Problems
Hi guys hope some one might have a suggestion on a radio problem, I'm out of idea's. 2012 Ultra Classic external speakers quit working, the head set still works. The 3 way speaker switch don't work on external or in the middle position, only on the headset only position. I actually have another radio from awhile back my radio got wet and went blank so I bought a used radio on ebay. I sent my original to Iron Cross Audio for repairs. When it came back I put it back in and put the used radio in a box. The reason was the faceplate had some fluid in it but the radio worked fine So I tried pugging it into the wiring harness and had the same problem. So two radio's same problem. I thought it must be the speaker switch so I replaced it, still have the same problem and I'm $97 poorer. Anyone have any idea's on what could be causing this? I guess I could have two radio's with the same problem, but that sure seems odd.
Old May 13, 2020 | 04:27 PM
LQQK_OUT's Avatar
LQQK_OUT
Old May 13, 2020 | 05:13 PM
The Nev's Avatar
The Nev
Well thanks good info to have, but the old radio worked when I took it out and it is now doing the same thing. Do you think that two radio's would have the same problem?
Old May 15, 2020 | 04:39 PM
The Nev's Avatar
The Nev
Just for info in case anyone else runs into this problem it ended up being the radio. I'm told usually it's the radio or the 3 way speaker switch, and rarely a short in the wiring.
wizardfitznq
Mar 31, 2020 07:31 PM
bk5
Apr 11, 2019 07:01 PM
myred55
Jun 30, 2012 09:06 AM
alame
May 2, 2012 12:04 PM
SharkBite
Oct 1, 2009 05:11 PM
