PC III cable
Old Jul 24, 2007 | 08:42 AM
larry5h's Avatar
larry5h
Default PC III cable
Since I don't have a laptop can I buy a longer USB cable to hook up from my office to the bike?
Old Jul 24, 2007 | 09:07 AM
chappy_2336's Avatar
chappy_2336
Default RE: PC III cable
You can go about 15 feet, then distance can become an issue due to power capablilities for your device
Old Jul 24, 2007 | 10:33 AM
rickoshay45's Avatar
rickoshay45
Go to a good Radio Shack, Circuit City or the like. There may be wireless links you can use. Also there are amplifiers designed to overcome the line loss issue. I used to do a lot of this but not any more. But I'm sure there are solutions that, with a little ingenuity will work. Post if you get it going. Lots of others will find it usefull.
Old Jul 24, 2007 | 10:41 AM
Wecroft's Avatar
Wecroft
With the Serial cable there is no length restriction. I run a 75' cable from my desktop to my garage.
iclick's Avatar
iclick
They also make extender cables that allow longer lengths. Here are some at Newegg:
http://*******.com/2owdyz
Old Jul 24, 2007 | 12:07 PM
FLHT's Avatar
FLHT
ORIGINAL: larry5h
I didnt have a laptop either but I bought one on e-bay just for working on the bike for around 160 bucks
Old Jul 24, 2007 | 12:15 PM
glens's Avatar
glens
ou could enter "usb cable length restrictions" into google (done here for you).
The PCIII does not (to my knowledge, at least) draw any power from the cable so that wouldn't be a factor. The data rate may be low enough that it would work with quite a long cable; don't know about that either. It's probably a safe bet the the length restrictions pertain mainly to devices which require power and/or high data rates. As suggested, the PCIII may well require neither.
Why don't you just take your computer/monitor/keyboard/mouse out to the garage for a few minutes (assuming it has a USB interface)?
nineball
Audio Systems
Jul 31, 2016 09:42 PM
harley7316
Oct 18, 2013 11:12 AM
ssmith579
Apr 4, 2012 10:17 AM
cafedante
Exhaust System Topics
Jun 28, 2010 03:55 PM
Roadking Cal
Jan 1, 2010 02:09 PM
