Cruise control
Old Jul 4, 2020 | 11:04 AM
Jeffrey Mitchell's Avatar
Jeffrey Mitchell
Stage III
Default Cruise control
While riding my back brake pedal went soft the next day while riding it was fine but cruise control won't work
2002 Ultra Classic
Old Jul 4, 2020 | 11:08 AM
EdwardK's Avatar
EdwardK
Check/change the rear brake light switch. Common failure.
Check your brake light, I bet it's stuck on. That's why cruise wont work.
Old Jul 4, 2020 | 01:41 PM
Jeffrey Mitchell
Stage III
You're right that's what I finally got to that point through videos yesterday I lost pressure in my back brake pedal but then regained it haven't had a problem would that have been caused by the brake switch failing
Old Jul 4, 2020 | 04:33 PM
EdwardK's Avatar
EdwardK
I'm not an expert but it's happened to me twice ( different bikes ). I'm guessing the guts failed and when you hit the brakes you put more fluid inside the switch causing the pedal fade, then you basically pumped it back up and it held. I had one fail completely and I lost all rear brakes. Switch was letting the brake fluid squirt out. Good thing is, the brake light switch is an easy repair and probably the cheapest part you'll ever replace. Do it fast and you won't even have to bleed the brakes.
Old Jul 4, 2020 | 04:41 PM
Jeffrey Mitchell
Stage III
Thanks bro I'll be sure to pass on that knowledge
05 RGLIDE
Mar 5, 2012 04:16 PM
ramblin
General Topics/Tech Tips
May 24, 2011 10:06 PM
MangoMike
Jan 16, 2010 08:12 PM
Steven1953
Aug 26, 2009 08:37 PM
SMenasco
Aug 20, 2006 12:51 PM
