Downshift question
Old Jul 25, 2007 | 07:29 AM
Anthony8858's Avatar
Anthony8858
Default Downshift question
I've had my RKC for almost 3 years. Tpically, as I come to a stop, I might find myself downshifting through 2 gears at once. (maybe third to first as I come to crawl).
Lately, when I attempt to do this, it won't catch the gear right away. I would have to release the clutch a bit, then downshift one gear at a time. It won't let me downshift through two gears at once.
It used to.
Any ideas?
Old Jul 25, 2007 | 07:39 AM
murph3204's Avatar
murph3204
Default RE: Downshift question
I hate to say it may be fluid related in fear that it'll start an oil debate thread but...
I have thought of experimenting with different brands of trans fluids myself since mine does the same thing as yours on occasion. I'm currently using Syn3 and have thought about trying Redline due to what I've read here about how it'll smooth out the shifting.
Old Jul 25, 2007 | 07:50 AM
Anthony8858
I have HD synth in he entire bike.
Could the oil be breaking down after 1500 miles?
Old Jul 25, 2007 | 09:05 AM
HogBoy's Avatar
HogBoy
I use the Redline MTL oil in primary. I can't say I've noticed the problem you're describing. Interesting, however.
Old Jul 25, 2007 | 09:38 AM
Zimbob's Avatar
Zimbob
primary chain need adjusting??
Old Jul 25, 2007 | 09:54 AM
PhilM's Avatar
PhilM
ORIGINAL: Zimbob
Bingo!
Old Jul 25, 2007 | 10:55 AM
Kahuna's Avatar
Kahuna
Personally, I am against Syn3 or using any 20w50 in the transmission! Although the manufacturers said you can, you also have to be a bit skeptical. Although I am biased toward Amsoil, I still don't use the engine oil in all three holes. I'm still using the Severe Gear 75w90 in my tranny and 10w40 in my primary. I'm sure others will have different thoughts on this. So, I'll leave it here.
ORIGINAL: Anthony8858
Old Jul 25, 2007 | 10:57 AM
the_icemAN's Avatar
the_icemAN
I was gonna vote for Chain Tensioning... Zimbob/PhilM beat me too it. Sounds more like there is a little slack there in the primary chain..... definately worth looking into.
Old Jul 25, 2007 | 09:31 PM
Anthony8858
Is there a way or me to check the primary chain?
Would I be able to tell is it's too loose?
Of course....Am I qualified to tighten the slack, if any?
Old Jul 25, 2007 | 09:38 PM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
1st question is: Do you have the shop manual for your bike?
2nd question is: Do you own a torque wrench?
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
