Heavy Rider ....
Old Jul 12, 2020 | 07:19 AM
Rob72's Avatar
Rob72
2nd Gear
Default Heavy Rider ....
Hi guy’s, i’m on a 19’ SGS , most of time ride 2 up, my weight + passenger weight = 350 lbs + 220 lbs= 570 lbs , need help with rear shocks .....Progressive ? Legend ? Please ppl with the same problem let me know which way to go not to bottom out on every road . We are planing some longer trips so will appreciate some help.
Old Jul 12, 2020 | 09:00 AM
GalvTexGuy's Avatar
GalvTexGuy
Contact Pro-Action. They can customize rear shocks that meet your weight requirements.
Old Jul 12, 2020 | 09:14 AM
BigMike67's Avatar
BigMike67
i'm over 400lb and run the progressive 444 with heavy duty spring and it's a bit stiff... sounds like it would be perfect for you! if you call them they will set up the shocks for you
Old Jul 12, 2020 | 01:56 PM
TriDan's Avatar
TriDan
Progressive 944 with extra heavy duty spring. Not a problem.
Old Jul 12, 2020 | 04:11 PM
Boomer1143's Avatar
Boomer1143
Progressive 944 with the extra heavy duty springs gets it done for me.
Old Jul 12, 2020 | 07:41 PM
Eng5ive's Avatar
Eng5ive
Pro action, RWD, Ohlins,etc will all be able to build a shock with a spring rate that will suit your weight and the weight of luggage. It's pretty much take your pick, all will be better than stock. Just need to choose how much you want to spend and what if any adjustments you want other than preload.
Old Jul 12, 2020 | 08:20 PM
Dynamick's Avatar
Dynamick
Weight of OP + his passenger already exceeds max. added weight allowed for a Street Glide by 40 lbs....
Old Jul 12, 2020 | 10:09 PM
Dano523's Avatar
Dano523
Ditto, and would be hard pressed to even find the needed springs to swap out the stock ones for a few hundred dollars.
Hence quick check with Race tech, and stock fork spring is .74KG/mm, and at just 499lbs that the bike is rated for, would need 1.65kg/mm springs isntead.
So for front fork springs, would be some where in the 1.68 range, and special order springs to start with. Same with rear shock replacement springs as well.
https://racetech.com/ProductSearch/1...20Special/2019
Old Jul 13, 2020 | 01:11 AM
Kyle Moore's Avatar
Kyle Moore
I am running the legends 13 inch arc shocks with heavy duty springs on my road glide. Amazing shock. I am 290 lbs and have a trunk in my bike, so it’s just enough weight to compress the shocks to their recommended sag with only 1 turn of preload one the springs, and when I have a passenger they still feel great. I’d go with legends front and back on your bike.
Old Jul 13, 2020 | 04:45 AM
grbrown's Avatar
grbrown
Wink
Rob, hi from the UK. As you're in Europe I suggest contacting a local Ohlins dealer or distributor. Your combined weight is going to challenge any suspension supplier, to be honest, so I suggest you find someone nearby to talk to.
JayFan
Mar 17, 2017 05:58 PM
mpaquette
Aug 10, 2016 05:32 PM
Bill K.
Jan 7, 2016 08:30 PM
lukemc7
Nov 23, 2010 12:01 PM
dagored11
Sep 21, 2009 07:40 PM
