Gauges
ORIGINAL: 04harleyboy
Yep, 32psi is were the oil pressure gauge should read cruising.The Air temp gauge is just to fill the hole until you buy the oil temp gauge. It is a useless piece of equipment, it messures the ambient temp inside your faring.
No, what everyody whose bike is under warranty is bitch, bitch and bitch to
moco about it. Not remove it and buy a different gauge from them giving them even more money.
They're smart not to fix it. Because if they don't a lot of you will spend 200+ on the oil temp from them. Hey more money for them.
Where if they fix it less income for them.
ORIGINAL: bdavis
What does the "Air" gauge do? If it is supposed to give the temperature it is about 30 degrees off.
Thanks,
Barry
Thanks,
Barry
Its not NASA accurate but mine's "in the ballpark". Sometimes I am not sure if I am hot or cold so I go by what it says.
Capt. Mike
Dec 15, 2009 10:12 AM
