Fender extentions
Old Jul 22, 2020 | 06:42 AM
Harleysnhummers's Avatar
Harleysnhummers
Stage II
Default Fender extentions
Hi guys, i have a cvo 2018 Ultra limited and im wanting to put a fender extention on it, my question is this,
• are the fenders different to other tourers (streetglide) ?
• do all fender extentions fit ?
Old Jul 22, 2020 | 12:18 PM
Ultra 99's Avatar
Ultra 99
The rear fenders are the same on the touring models. The differences are where the cutouts or holes might be for mounting lighting, i.e. turn signals or fender lights. Also, they don't all have the holes for the fascias (extensions). You could use your fender and add a fascia by drilling the holes for it. You have to make sure the wiring is compatible for the lighting you might be adding. I took a fender from your model and used it for my 2019 FLTRU and added a CVO Street Glide fascia to it with the vertical lighting. I then bought the harness for a 2014 CVO Road King that was plug and play with the features I needed. You just need to do your research.
Old Jul 22, 2020 | 12:42 PM
Hoginedgewood's Avatar
Hoginedgewood
I got a free trailer hitch for my 19 road king. Had about a 4” gap. I found a fascia from a street glide for cheap. Needed to remove the fender and drill holes but I just bought some 3M tape and I’ve put several thousand mile so far. I skipped the light because it wasn’t plug and play. Your results may vary.
charles8606
May 9, 2020 11:29 AM
WestPalmBop
Dec 22, 2017 02:36 AM
smithmx47
Jun 23, 2014 07:52 AM
dvsv99
Oct 4, 2013 11:01 PM
11rkc
Apr 11, 2012 12:43 PM
