Engine noise
Old Aug 10, 2020 | 12:23 AM
ROCKOUT Rocker Products
Sponsor
Originally Posted by sch5034
John, I'm curious if installing this kit would affect the ESP service plan I have with Harley? I watched the video on your website, and I think the bike has been making that noise since I got it - just kind of noisy when approaching 3000 RPM, seems to be more pronounced when it's hot out. The current noise I'm hearing just started recently, and really sounds like it's not getting enough oil... like when you change the oil in a car and first start it. It's not all the time, just right after I've gone up a large hill under medium to heavy acceleration, and then I let up so I'm basically coasting. Once I get on the throttle again, the noise stops.
For $16, I'll certainly keep this kit in mind!
Strictly speaking, if you swap a bolt from your bike with a chrome aftermarket one you may void your warranty. Rockouts can in no way damage your engine. Tens of thousands of inserts installed, not one mention of damage. Ever. If there was you certainly would read about it here.
Besides... they are completely concealed once installed.
Cheers
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Aug 10, 2020 | 05:22 AM
NELS's Avatar
NELS
Could be a weak lifter. I don't know of any way to prove it though without replacing. Also , maybe a baisley oil pressure spring?
Old Aug 10, 2020 | 07:32 AM
ratpick's Avatar
ratpick
I get the noise when I've reached the top of the hill, so I'm going from medium to heavy acceleration to just shy of complete roll off - essentially coasting, or just enough throttle to not be engine braking. Happens if I shift up a gear (into 5 or 6) or if I just let up on the throttle in the same gear. Speeds are probably between 50 - 70mph. RPM's seem to be right around 3000. I've checked all of the fluids, everything is right where it should be. I've used 93 octane gas since I got the bike last spring. I've put about 6500 miles on it, and the noise just started happening within the last few weeks. It will make this noise until I either give it more throttle or completely let off - so it seems like it's just when there is no or very little load on the engine.
If it's making noise only when you're completely unloading the drive train it certainly isn't "pinging" and I wouldn't think it'd be the valve train either. Just a guess but I'd be more suspicious of primary or transmission, though I'm not sure noise could be coming exclusively from the right side in either case...
I'd describe the problem thoroughly to service dept and ideally directly to mechanic and they should be able to reproduce issue and give some feedback.
Old Aug 10, 2020 | 09:17 AM
matt_eglide's Avatar
matt_eglide
It’s most likely slop in the rocker assembly in the top end, specifically the shaft that runs through the rocker arms banging against and back and forth with the bolts holding the entire rocker assembly to the heads. The bolts are hardened by the factory and the tolerances in there aren’t the tightest either.
Rockouts provide a very nice solution and got rid of the ticking in my engine after installing them. It’s a fair amount of work to get them in but well worth it if you’re dealing with any amount of annoying tick coming from the top end.
HTH
Old Aug 13, 2020 | 10:22 AM
sch5034's Avatar
sch5034
6th Gear
Well, the dealership just called back - they are saying that they couldn't reproduce the issue, and that everything is fine. I'm planning a 7 day trip on the bike starting Labor Day weekend, and I'm really worried about doing serious damage to the engine.
Old Aug 13, 2020 | 12:13 PM
Johnnypop's Avatar
Johnnypop
Well that opens up other options
1 trade it off for new
2 find an independent or another opinion
3 ride it and put some miles on it
4 rent a machine for your trip
5 get aaa and hog insurance and hope for the best bring it home in a uhaul truck if it breaks down
What would need to happen to give you faith in the machine to make the trip?
Old Aug 13, 2020 | 12:37 PM
Turbomunkey's Avatar
Turbomunkey
If your fluids are all good and the dealer couldn’t find an issue, then ride on. Some things that come to mind are both your lifters and your cam tensioner work off oil pressure, so your being quite specific about the noise occurring after a climb / load brings those items to mind. Might be the hydraulics having to load or unload some oil pressure to readjust, so to speak. Does your gauge show oil pressure?
Old Aug 13, 2020 | 12:40 PM
Steve Sportster's Avatar
Steve Sportster
I'm having a rather loud "clacking" sound at cold startup on occasion. Not always. It's a lifter (one or more). My local dealer is going to replace them under warranty even if they don't hear it when I bring it in. Your problem may be lifter caused, too.
Old Aug 13, 2020 | 03:57 PM
FPV's Avatar
FPV
I've started noticing a ticking kind of sound from the right side of the engine. I'm hearing the noise after the bike has been running for half an hour or more, and it seems to start up after I've gone up a long hill/mountain and then let off the throttle most of the way. It almost sounds like the engine isn't getting oil at that point - sounds dry, clackety (hard to describe!). It will usually go away after a few seconds, almost like the engine needs to recover after pulling hard for a while. Seems to be most noticeable around 3000 rpm's.
Not saying this is your issue but sure sounds the same. What you describe is exactly what I went through a few years back. Same model bike with about same mileage 2010 FLHTK 103" w/about 29K mi. Loud ticking from valve train but only when engine was heat soaked and only when off throttle on down side of hill or off throttle on a long exit ramp after an 80mph run on the freeway. Soon as given some throttle noise would quit. Oil pressure was steady at 32psi and no oil burning or visible smoking. Shop couldn't reproduce issue and said ride it. Knew something wasn't right but didn't have the extended warranty like you so decided to dig into it myself.
Turned out being a torn valve stem seal on the rear exhaust valve. Rubber had torn free from the top hat and was floating on the stem. Can't explain why a rubber piece produced that obnoxiously loud ticking noise in the manner that it did but it did nonetheless. After removing the rear rocker box problem was evident.
Didn't want to pull the head so picked up the valve spring compressor kit from NubTool.com and in less than one afternoon did all the valve stem seals in my garage. The tool uses an air compressor to pressurize the cylinder in order to keep the valves closed while the springs are removed. Also dropped in a set of RockOut inserts while things were apart. Over 20K miles later engine is as quiet as a twin cam can be.
https://store.nubtools.com/product/h...-complete-kit/
Old Sep 7, 2020 | 06:54 AM
sch5034's Avatar
sch5034
6th Gear
Well, I installed the rockout sleves last week, and it seemed better for a day or two, but I'm back to the same issue again. If anything, is say it's becoming more pronounced - any time I've been under heavy acceleration for a while then let up. It's making the noise now even I completely let off the throttle.
Oh well, I'm a few hundred miles into a trip, so we're just going to roll with it and hope for the best! BTW, skyline drive is beautiful!
