Larger Windshield
Old Aug 24, 2020 | 01:16 PM
tdeffler's Avatar
tdeffler
Stage III
Default Larger Windshield
Hello. I just bought my first HD, a 2020 Road King. I'm tall (6'4") and the stock windshield is a trifle short for me. The wind hits my face.
If you've moved to a taller-than-stock windshield, is the steering noticeably affected or is it pretty neutral to make the switch?
Thank you.
Old Aug 24, 2020 | 01:48 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Went taller than stock on my 04 RK. No discernible impact on handling that I’ve ever noticed.
Old Aug 24, 2020 | 01:59 PM
tdeffler's Avatar
tdeffler
Stage III
Thanks, foxtrapper.
Old Aug 24, 2020 | 02:08 PM
ve9aa's Avatar
ve9aa
I've tried 2 different height stock windshields on my RKC and 2 different fairing mounted windshields on the same bike. If there's a difference in handling, I can't tell.
You should be looking OVER the windshield (you probably know that) with the windshield at aprox nose or moustache/mouth area-height/. A little wind in your face is normal.
Most are slightly adjustable. Either bracketry or tilt angle. They're all a little different. Even raising or lowering your seat or suspension changes this geometry.
HTH
Old Aug 24, 2020 | 02:11 PM
tdeffler's Avatar
tdeffler
Stage III
Oh, I'm looking over it. The windshield comes up to my Adam's apple.
Old Aug 24, 2020 | 02:15 PM
RKZen's Avatar
RKZen
Welcome to the HD Forums.
If the stock shield seems a smidge short, you might look into a replacement stock shield with a recurve. That usually pushes the wind up another 1 1/2". I think the stock is 19 1/2", at least it is on my '13 King. I could feel a slight wind buffet above my head with the stock shield. With a stock height and recurve, it's pretty smooth now.
Clearview Shields makes a 21" and 24" with and without the recurve if you want to go taller. You can check it out here.
Old Aug 24, 2020 | 02:19 PM
ve9aa's Avatar
ve9aa
I had to cut mine down....I am not blessed with height like you, but I bet if I was, I could've very carefully drilled new holes and increased the height just a little bit.
Then again, you can always buy a new (taller) shield like others will tell you.
Old Aug 24, 2020 | 02:20 PM
RK_Classic's Avatar
RK_Classic
Long ride windshield makes a re curve in 16" 18" and 20", I have one on my rk and really like it.
https://www.longrideshields.com/
rk classic.
Old Aug 24, 2020 | 04:50 PM
TracerBullet's Avatar
TracerBullet
Should be negligible
Take a look at Freeedom Shields. Customer service is outstanding......and they make a great product
Old Aug 24, 2020 | 07:56 PM
MyFavRk's Avatar
MyFavRk
I've been using Clearview for the past 10 years , top notch . You can order them any way you want , standard or wide , tinted , curved etc . I have the light tinted grey , 2 years old and still looks new . They come a little thicker than stock as well , so that's a plus . No , I don't work for them !
https://www.clearviewshields.com/
