front end shake ~30 to 35mph
Old Aug 29, 2020 | 04:19 PM
kblah76's Avatar
kblah76
6th Gear
Default front end shake ~30 to 35mph
I bought a 2020 ultra near sturgis after my eglide broke down. There was some issue with the front tire where the bars shook any where over 30. They tried balancing the tire with no luck and ended up replacing it. I'm am back home in illinois and i've noticed if i'm easy accelerating or decelerating that the bars jiggle a bit right between 30 and 35, nothing terrifying, just noticeable. It goes away after that speed.
First off, is this normal for this year/model?
Second, since its really only at that speed I can't imagine its a tire out of balance. Steering bearings maybe?
Old Aug 29, 2020 | 06:05 PM
btsom's Avatar
btsom
YOU know exactly what "jiggle" means to you. It is not a precise or technical term. Do the bars wander left and right or up and down? Among the dangers of trouble shooting a new bike on the internet is that if you go in for service and say the head bearings are loose, they will not check front wheel bearings, tire irregularities or anything else on the bike that might cause the problem. If it doesn't get any worse, tough it out until you get home and lay in the lap of your local dealer and let them check everything that might contribute to the problem. Are you always in the same gear when it happens, suggesting it could also be engine or drive line induced. What happens if you pull in the clutch while the bars are "jiggling"?
Old Aug 29, 2020 | 06:23 PM
NorthWestern's Avatar
NorthWestern
What did the dealer say it was?
EDIT: I see you are still on the road. I would still have it checked, that sounds sketchy
Old Aug 29, 2020 | 06:42 PM
kblah76's Avatar
kblah76
6th Gear
Sorry, i am back home.
Its a slight side to side, i have not tried it without the clutch in.
Old Aug 29, 2020 | 06:51 PM
MTBIG G's Avatar
MTBIG G
Not normal at all for a new bike. If front tire pressure is ok, the stearing head bearing needs to be tightened.
Old Aug 30, 2020 | 01:16 PM
ajnigli's Avatar
ajnigli
If it is a brand new bike when you bought it, could be a bad tire. I just had my tire replaced with harley dunlops and front tire had shake at 35-40, pulled to the left when let go of handlebars, and a noticeable shake above 70. Dealer said steering head bearings could be it but since they replaced the tire and the issues happened after that, they ran their tests and it ended up being a bad tire. Issue and steering head bearings never touched adjusted,
Reece64
Aug 2, 2014 07:59 PM
stro1965
Sep 22, 2011 07:12 PM
blackswampbiker
Jun 14, 2011 09:34 PM
jay72
Road Trips
21
May 20, 2011 10:50 AM
Jughugger
Sep 6, 2007 07:21 PM
