Front rotor bolts
Old Oct 4, 2020 | 08:33 PM
miketv84's Avatar
miketv84
Default Front rotor bolts
Anyone know of a black rotor bolt for the front rotors on a twin cam? Harley's stock # is 3655a. Lyndall makes 2 types. A low profile for $100 which seems a bit much. Or the arp 12 point for $30 but I'm not sure if they would be too tall and hit the forks. Google search comes up with an M5x10. Not sure if that's correct or not.
Old Oct 4, 2020 | 08:52 PM
dawg's Avatar
dawg
https://www.denniskirk.com/drag-spec...prd/275640.sku
Old Oct 4, 2020 | 08:54 PM
miketv84's Avatar
miketv84
Thanks !
Old Oct 5, 2020 | 06:36 AM
eighteight's Avatar
eighteight
McMaster - Carr
# 91255A582
50 pcs for $11.64
Old Oct 5, 2020 | 08:04 AM
twincam10353's Avatar
twincam10353
ARP makes top-quality hardware.
EDIT: If you read the description on Lyndall's website: "ARP Bolt kits are also available for sprockets, pulleys, and rotors (these will not fit rotors on a 39mm/narrow glide front end, as the 12 point head is too tall and will hit the forks.)"
Old Oct 5, 2020 | 08:43 AM
miketv84's Avatar
miketv84
McMaster - Carr
# 91255A582
50 pcs for $11.64
Perfect. The drag specialties is out of stock so I'll probably order this.
Old Oct 5, 2020 | 08:44 AM
miketv84's Avatar
miketv84
Yeah saw that , probably a no go. Someone posted a mcmaster screw link that looks good.
Old Oct 5, 2020 | 11:18 AM
twincam10353
Well we don't have to guess here, if you have a 39mm front end they will not fit.
Old Oct 5, 2020 | 04:01 PM
Sam2010's Avatar
Sam2010
I always thought the head was a little bit smaller on the drag specialties. I went back to the stock bolts because it seemed to Center the rotor better. The head of bolt matched the inset hole on rotor. If ya know what I mean.
Old Oct 5, 2020 | 04:13 PM
miketv84's Avatar
miketv84
I ordered the mccasters, see how they are.
