Oberon Clutch Leve causing slipping?
Old Oct 10, 2020 | 11:36 AM
ryguylears's Avatar
ryguylears
Default Oberon Clutch Leve causing slipping?
Here to see if anyone is having the same issue. I installed the Oberon Adjustable clutch lever on my 2018 RKS and i noticed today when I got on the throttle, the engine would rev and I wasn't getting power, AKA my clutch was slipping. I had it on the "1" setting which caused me to lose the ability to start in gear, but now this...not too happy.
Old Oct 10, 2020 | 01:47 PM
JakeC7R's Avatar
JakeC7R
Sell it and get a softbrake lever. I had the Oberons and they were too short for me. The softbrake lever is basically just a stock lever that is heated and bent, giving a engagement point 1" closer to the bars.
https://softbrake.com/product-catego...clutch-levers/
Old Oct 10, 2020 | 05:41 PM
champ198's Avatar
champ198
i have Oberon clutch and brake levers love mine they are both set on 3 if i go to 2 it dosent want to start since it is still engaged but 3 is perfect for me.
Old Oct 10, 2020 | 08:54 PM
lenbt's Avatar
lenbt
Soft brake levers all the way.
Old Oct 11, 2020 | 07:27 PM
95th 1200's Avatar
95th 1200
If you're having difficulty with the engagement point of the lever travel, look into having the AIM Lightforce or the Muller unit installed. Feels just like a cable system with the easy pull, engagement is closer to the grip and linear.
Old Oct 12, 2020 | 06:43 AM
BuckeyeDeuceCVO's Avatar
BuckeyeDeuceCVO
I have the same issue with my Oberon. Called the company and it was suggested checking the reservoir to assure it was at max level. If topping it off didn't work, he offered to take it back with full refund.
Newrider1995
Jun 3, 2016 06:52 AM
bigredwing
Sep 1, 2011 11:00 AM
Joshua
Apr 11, 2010 03:01 PM
freebyrd
Jun 6, 2008 09:22 PM
wydopn231
Apr 13, 2008 06:50 AM
