Progressive Suspension 10-2003 Drop-In Fork Lowering
Old Oct 14, 2020 | 08:42 AM
vdude's Avatar
vdude
Default Progressive Suspension 10-2003 Drop-In Fork Lowering
Can anybody tell me how hard this to do on 2004 roadking? Will i have to drop the fork?
THANKS
Old Oct 14, 2020 | 12:44 PM
Jaftica's Avatar
Jaftica
THANKS
You will have to slide the fork down from the upper triple tree clamp at a minimum. You may as well take it completely off. As for lowering the front end goes I quit using the high priced springs and simply dropped in shorter dampner valves, Far less expensive than buying new springs.
Old Oct 15, 2020 | 09:06 AM
billgran's Avatar
billgran
If you do not have one yet, I have a brand new in the box Progressive Suspension lowering kit for a 2004 Road King and others for $50 plus shipping. I traded my 2004 RK in for an Ultra 2 weeks ago and never got to use the lowering kit. I live near the Daytona, FL area.
Old Oct 15, 2020 | 04:50 PM
Taxgod4u's Avatar
Taxgod4u
fwiw, I just installed the Progressive lowering fork springs on a '14 SGS. It is a snap to do. Takes about 2 hours if done right. Only bitch is finding an Allen wrench to fit the damper bolts in the bottom of the forks. I could not buy one large enough so took an old one and ground it down to fit. Rides same as stock w/ 61K on it. Just do it!
dmbeveryday
Nov 15, 2010 09:21 PM
albertaman
Jun 12, 2010 11:08 PM
ROBSREDFORD
Jun 25, 2007 09:28 PM
ROBSREDFORD
Jun 23, 2007 05:22 PM
MAX EVO
Nov 4, 2006 08:31 PM
