PROGRESSIVE FRONT FORK SPRINGS/
Old Nov 4, 2006 | 02:01 AM
MAX EVO's Avatar
MAX EVO
Default PROGRESSIVE FRONT FORK SPRINGS/
Where can you purchase the Progressive low profile front fork sprigs? Can you get them at Eastern Performance?I know they sell the rear shocks.
Old Nov 4, 2006 | 02:11 AM
anubisss's Avatar
anubisss
Default RE: PROGRESSIVE FRONT FORK SPRINGS/
Try J and p...
Old Nov 4, 2006 | 02:16 AM
clayman's Avatar
clayman
ProgressiveÂŽ Suspension Fork Lowering Kits 1977-2006
An easy and inexpensive way to drop the front end one or two inches. Progressively-wound fork springs, spacers, and lowering components. Made in the USA.Note: Careful evaluation of fender-to-frame clearance required when installing any lowering kit
Read More >>
got this from j and p. Does anybody know if you would go with the 1 or 2 inch, i want to put the progressive 412s 11 inch on the back but not sure which to choose for the front.
Old Nov 4, 2006 | 03:35 AM
SKT's Avatar
SKT
Have you checked their homepage...I can't recall if these were one of the items you had to buy in a store or not.
Depends what you want to do, If your springs are still good, and you just want a lower stance, you could always slide them upwards through your triple tree.
Old Nov 4, 2006 | 01:00 PM
MAX EVO's Avatar
MAX EVO
Do you need to lower the front if you go with a 11 412's or can you get the reg progressive springs Pro's and con's thx.
Old Nov 4, 2006 | 08:31 PM
clayman's Avatar
clayman
From what ive always heard if you lower the back you need to do the front also or your handling will suffer.
VETERAN75
Mar 25, 2012 09:06 PM
Lilman
Oct 25, 2010 05:28 AM
Low E
Feb 16, 2009 05:13 PM
bailey40
Jan 26, 2009 07:32 PM
fstlane4me
Aug 12, 2008 08:53 PM
