'17 King Dash Panel Issue
Old Oct 14, 2020 | 08:58 AM
CrimSonami's Avatar
CrimSonami
Default '17 King Dash Panel Issue
Left turn and High Beam indicator out. Right turn and neutral indicator working.
What should I look for?
Old Oct 14, 2020 | 10:19 AM
eighteight's Avatar
eighteight
Failed light bulbs in dash ?
Old Oct 14, 2020 | 11:28 AM
CrimSonami's Avatar
CrimSonami
That's the first thought I had but I'm not familiar with the arrangement or best way to access. I've had the dash loose to run a fixed USB cable but haven't completely disconnected and looked at the construction.
Old Oct 14, 2020 | 12:16 PM
DuraGlide's Avatar
DuraGlide
The Rushmore bikes are canbus so you have input from the switch to the BCM and output to the indicator lights from the BCM. Just a guess but I'd say the indicator lights are LED. Are the lights working and just the indicators out?
Old Oct 14, 2020 | 12:42 PM
CrimSonami's Avatar
CrimSonami
Turn signal (front and rear) as well as headlight (high and low) are totally functional.
Thank you for the input.
Old Oct 14, 2020 | 01:04 PM
eighteight's Avatar
eighteight
Confirmed the "lights' are not servicable
they are integrated into the block on harness # 69200124
Old Oct 15, 2020 | 07:28 AM
CrimSonami's Avatar
CrimSonami
Thank you.
This "Parts Finder". Is it a download or dealership exclusive?
Old Oct 15, 2020 | 07:30 AM
eighteight's Avatar
eighteight
Originally Posted by CrimSonami
Thank you.
Just type in " Ronnies Parts finder"
Old Oct 15, 2020 | 12:19 PM
CrimSonami's Avatar
CrimSonami
Thanks for your help eighteight
Old Jan 9, 2021 | 04:59 PM
CrimSonami's Avatar
CrimSonami
Finally got around to ordering the replacement harness last week. Picked it up this afternoon and installed. Quick and easy plug n play but it didn’t work as expected. Dash display had nothing. The neutral indicator was illuminated even with the switch off. The turn indicators didn’t work as well as no high beam indicator. Removed and put the old one back in and it works just like before.
Dunno how it could be but did I do something wrong?
