Returning from ride in NC mountains and check engine light came on 20 miles from home. Got back to house and ran diagnostics and had three error codes - PO152, PO522 and PO562. Bike only has 6500 miles on it and less than maybe 600 miles since being serviced by dealer including installing a new battery. Could all these be related? Im no mechanic so would have to take to dealer which is 1 hour away. Wondering if should just try to clear the codes and see if they return?
P0152 Rear Oxygen Sensor High / Engine Rich
P0562 Battery/ECM Voltage Low
P0522 is a diagnostic trouble code (DTC) for "Engine Oil Pressure Sensor/Switch Low Voltage"
With these code and the information you posted I would. Clear them and ride see if they come back. Not uncommon to get the P0152 with a bike that has sat a bit. Po562 you did say you replaced battery P0522 oil pressures senor are know to go bad some will throw a code now and then before failing completely. Also you may try shut the bike off and turning it back on a bunch of times generally 5 and the codes may clear up. The will remain in memory. easier to just clear them.
Thanks for your responses. Ill try turning the bike on/off several times and if that doesnt work will go ahead and clear the codes and see if they come back.
