sand it smooth and fill where needed and sand it smooth. not difficult. I am not touching it so I dont know how flexible it is. but to wrap it that should suffice.
where would be the best place to look up the prep method to this? i mean what type of sand paper to use. I recall doing some body work a while back on my truck and i came across a site that broke down the stages.
The question is how much are you paying for the vinyl wrap? When I've looked into Vinyl wraps for cars, I was very surprised at how expensive they are - as much or more than a paintjob in some cases. Where I'm going with this is, if the vinyl wrap is very expensive, don't waste the money putting it one a repaired fairing. However, if it's cheap, then go for it and if its an issue later you can replace the fairing and have it matched later.
Now, if we go with fixing the fairing then wrapping it, I'd be afraid that any filler, even when well sanded, is going to show through the vinyl. I think it would have to be fully prepped for paint, then actually painted and buffed to a full shine, otherwise you'd see the texture through the vinyl. That's just what I THINK though, I have no experience with this. But, some good questions to ask your wrapper and I'd hope they would know
What that looks like to me is excessive paint film thickness and the resulting cracking because of that thickness. Included in the overall film thickness could be any or all of the following... primer surfacers, glazing putties, sealers, color and clear coats.
There is also the possibility that the cracks are originating in the substrate (stress cracks). The only way to determine this is to strip the finish down to the substrate and inspect the substrate.
If it were me I'd start by stripping the finish. The easiest way of stripping the finish from non-metallic surfaces, like the one here, is by carefully sandblasting. You could do it with conventional sanding but that's going to be extremely labor-intensive. If going that route I'd start with something like 40 grit and work my up from there. Chemical strippers are not a good choice, especially if the substrate material is ABS.
Once the finish is stripped and you can determine the condition of the substrate, you should be able to determine what next steps are needed.
thank you for all this information. Im going to try and sand it down starting with 40 grit.
Even to most minute imperfection shows up bad with a wrap. Plus a wrap,is designed to stick to paint, not bondo it primer. I’d ask whoever is doing the wrap, what they recommend.
Judging from the pics, I'd say that's gelcoat applied over fiberglass. Fairly common to see those exact types of stress cracks on boats. Google is your friend for repair techniques specific to gelcoat over fiberglass.
