Axle torque spec
I'm doing my 1k service and part of it is to check the axle torque. The bike is a 2020 touring model (FLHR). Does anyone have those handy they could share?
Thanks,
RLK
1,000 Mile Service Log
Mileage:
Item Serviced Serviced
Check operation of electrical equipment and switches
Check front life pressure (36 psi), inspect tread
Inspect front brake fluid sight glass
Inspect clutch fluid sight glass (hydraulic operated)
Check front brake and hydraulic dutch reservoir cover screw torque (12-15 in-lbs)
Check hand control fastener switch housing screw torque (35-45 in-lbs)
Check dutch lever handlebar clamp screw torque (60-80 in-lbs)
Check master cylinder handlebar clamp screw torque (60-80 in-lbs)
Replace engine oil and filter (Torque drain bolt to 14-21 ft-lbs)
Replace primary chaincase lubricant (Torque drain bolt to 14-21 ft-lbs & derby cover screws to 84-108 in-lbs)
Replace transmission libricant (Torque drain bolt to 14-21 ft-lbs)
Check right front engine mount end cap screw torque (42-48 ft-lbs)
Check engine mount to front crankcase screw torque (36-40 ft-lbs)
Inspect oil lines and brake system for leaks, contact or abrasion
Inspect fuel lines and fittings for leaks, contact or abrasion
Inspect rear brake fluid sight glass
Check rear brake reservoir cover screw torque (12-15 in-lbs)
Inspect brake pads and discs for wear
Check front axle nut torque (70-75 ft-lbs)
Inspect and lubricate jiffy stand
Check, adjust and lubricate (with HARLEY LUBE) brake and clutch controls
Check rear tire pressure (40 psi), inspect tread
Inspect and adjust drive belt and sprockets
Check rear axle nut torque (95-105 ft-lbs)
Inspect exhaust system for leaks, cracks and loose, or missing fasteners or exhaust shields
Lubricate fuel door hinge and latch with HARLEY LUBE
Road test to verify component and system functions
My dutch lever and transmission libricant aint much better either
Maybe someone with a '20 service manual can chime in here.
ETA: Found the correct torque spec in another thread, it's now 135-145 ft-lbs (they changed the rear axle and cam adjusters on the '20 models)
