2004 Road King Avon Heated Grip Install question
Old Dec 2, 2020 | 07:05 PM
skos's Avatar
skos
Default 2004 Road King Avon Heated Grip Install question
Instructions show to slip the wires through the hole/opening in the bars. I don’t have a hole/opening in the bars. I have stock bars.
Anyone install Avon Heated Grips? How?
Here is instructions from Avon.
https://www.youtube.com/watch?v=ccKO...ature=youtu.be
Old Dec 3, 2020 | 05:33 AM
jake24lt's Avatar
jake24lt
2 options: change your bars to 1 1/4" ( they have the holes in them ) or run the wires outside the bars you have ( assuming 1")
Old Dec 3, 2020 | 06:26 AM
EVOrider's Avatar
EVOrider
I’ve run internal bar wiring on several bikes over the years.
Just put the bar on a drill press and drill the hole. I typically drilled two holes side by side and then merge the holes together forming an oblong shape. Then fine tune it so there aren’t any burrs.
It makes it easier feeding wires through especially if wiring is coming from both sides of the bar.
dbdicker
Sep 8, 2019 08:21 PM
rjjj629
2014-2024 Touring Models
13
Feb 27, 2017 11:41 AM
Cosmic Razorback
Oct 17, 2016 07:34 PM
Da Shadow
Feb 2, 2013 01:37 PM
jackyl
Oct 6, 2006 10:13 PM
