Larger wheels
Old Dec 19, 2020 | 08:49 AM
tajar66's Avatar
tajar66
Default Larger wheels
Hello everyone,
I am looking for experience with installing a larger front wheel on my Ultraglide. I have been offered a set of enforcer wheels 19 front and 16 rear. Currently the bike is 17 front and 16 rear.
will they fit and what will it do to the handing.
Old Dec 19, 2020 | 08:15 PM
skratch's Avatar
skratch
as long as you use the stock sized rubber, direct fit. no changes necessary. the overall diameter of the 16'', 17'', 18'', and 19'' wheel/tire combo is virtually identical.
you may or may not notice any difference in handling. some do, some don't. but you will notice a slightly 'rougher' ride as the shorter sidewall on the larger diameter tires does not absorb road irregularities as much as the taller sidewalls do. i don't find it to be a problem.
Old Dec 20, 2020 | 08:30 AM
tajar66's Avatar
tajar66
Thanks Skratch
Old Dec 20, 2020 | 08:47 AM
Uncle Larry's Avatar
Uncle Larry
This might help ??
https://www.discounttire.com/learn/t...SAAEgLpcfD_BwE
Old Dec 20, 2020 | 08:48 AM
todd-67's Avatar
todd-67
That pretty much covered the bases. From my experience with the different wheel tire aspect ratio the ride quality goes down with the stiffer side walls on the larger rims. It's not a huge issue but I can feel it on sharp edged expansion joints in the bars when I go from my SG to my RK.
Old Dec 20, 2020 | 09:54 AM
decencyxdefied's Avatar
decencyxdefied
I went from 16 to 18 and didn't notice anything other than it looked better
Old Dec 25, 2020 | 03:13 AM
RiderX's Avatar
RiderX
On my '17 Street Glide Special, I went from a 17" to a 19" and did not notice a difference in handling at all. Actually the ride comfort was pretty much the same. The only time you are going to notice a drastic difference is if you jumped to like a 26" wheel. 19" is the largest you can go without having to change fork, fender, and other components.
Old Dec 25, 2020 | 09:18 AM
RKZen's Avatar
RKZen
Actually not true. Many on here have a 21" front wheel, including myself, without changing anything. Most common mod is to enlarge the fender mounting holes to provide enough clearance on the rear portion of the fender when the tire expands a bit when riding.
Ed D
Nov 16, 2020 02:27 PM
tfalcon
Aug 5, 2016 10:10 PM
Mouse in my cup
Sep 7, 2014 07:56 AM
rodhotter
Wheels/Tires
Jul 3, 2010 09:04 PM
cchart
Mar 27, 2007 10:47 AM
