H4 headlight
Old Dec 23, 2020 | 04:11 PM
1canvas's Avatar
1canvas
Default H4 headlight
I’m needing a headlight for my 01 RK and see it takes a 4H light, are they all the same or is there better brands?
Old Dec 23, 2020 | 04:32 PM
eighteight's Avatar
eighteight
in my experience in cars( bike is led) the extra bright ones have a shorter life.
the blue ones are an annoying affectation
Old Dec 23, 2020 | 04:53 PM
Toypuller's Avatar
Toypuller
Agreed. I replaced my RK stock with a Siverstar, low beam went out a month later, put the second of the 2 pack in, same result.
Old Dec 23, 2020 | 05:38 PM
Sparkee...'s Avatar
Sparkee...
I used the Silverstars on my car for a few years. They would only last approximately 1 year. It pissed me off when I found they were only available in pairs. But when one went the other was only good for a week or more so it was best to change them in pairs. I got tired of changing them every year and went back to to cheap ones.
Old Dec 23, 2020 | 05:42 PM
Hasher's Avatar
Hasher
If you can afford it, replace it with an LED headlight. If not, you can get a 55 watt low beam and a 100 watt high beam. (55/100).
Better than stock but no where near as good as a modern LED.
Old Dec 23, 2020 | 05:57 PM
1canvas's Avatar
1canvas
Looking up lights I see the same thing posted. I don’t ride much at night so maybe an OEM bulb for reliability.
Old Dec 23, 2020 | 06:27 PM
Tcrafty's Avatar
Tcrafty
Amazon has some hella 55/100 bulbs pretty cheap. I put one in my other bike and it was much brighter. I also installed a relay inline with the bulb and just used the switch to throw the relay. Didn't want to smoke the switch. It lasted for years.
For this bike I just installed LED. Better, once you get used to the different kind of light.
Old Dec 23, 2020 | 07:19 PM
Dynamick's Avatar
Dynamick
Some bulb manufacturers, such as PIAA, offer H-4's specifically for powersports applications that are more resistant to vibration. That's what kills the other brighter bulbs like Silverstars.
After using those in several bikes I find they last much longer. But I've since moved on to LED's.
Old Dec 23, 2020 | 07:52 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
You aware that you can't touch the glass on the H4 bulb? The oil from your skin will cause a hot spot and blow the bulb, after the install wipe the bulb glass down with some rubbing alcohol. Just my 4 cents, inflation..
Old Dec 23, 2020 | 09:10 PM
86glider's Avatar
86glider
I put in an led,fan cooled H4 bulb from Amazon .It cost me like $8 or $9. Works great and has lasted 3+ yrs so far. The original bulbs are like a weak candle.
