2014 Street Glide won't start need Help
Old Jan 9, 2021 | 06:08 PM
NJBikelover66's Avatar
NJBikelover66
Stage IV
Default 2014 Street Glide won't start need Help
Hello Gents, I have been a user of this site for a long time and have benefited from all the advise but this one is different. I have a 2014 Street Glide 103 Project Rushmore. the Bike wont start, I have no codes, the bike will start with starter fluid in the intake. so far here is the point I'm at, I have replaced all of the fuel lines, fuel pump and regulator and filter so the tank is all new parts. new fuel injectors and MAP sensor, new Crank Position sensor, battery and coil. Thunder Max ECM and I have tried to use the stock ECM as well. Sent a Down Load to Thunder Max and they see no issues from the diagnostic. I have fuel pressure 60psi I have spark and had the battery tested to make sure it good. Again the bike will start with starter fluid. Anyone have any idea how to proceed? Kind of geaking out over fixing this my self but will give in a take to a shop if no ideas. thanks for any advise or experiences you may have had like this.
Old Jan 9, 2021 | 07:16 PM
702's Avatar
702
If it starts on starter fluid but not otherwise, you have a fuel delivery issue. Since you have fuel pressure, you'll need some noid lights to check injector pulse and go from there.
Old Jan 10, 2021 | 07:54 AM
NJBikelover66
Stage IV
that might be over my head 702, I had to look up noid lights to see what they are. my plan today is to check with a test light to see if i get voltage to the injectors. is that the same?
Old Jan 10, 2021 | 09:44 AM
RK_Classic's Avatar
RK_Classic
Do you hear the fuel pump come on? have you checked all the fuses, also is the fuel line connected to the tank fully?
rk classic.
Old Jan 10, 2021 | 10:48 AM
702's Avatar
702
^^^This might be your answer.^^^
You've already thrown the kitchen sink at it, maybe it's time for a trip to the shop. Good on you for trying though.
Old Jan 11, 2021 | 04:41 PM
NJBikelover66
Stage IV
rk classic.
Yes to all your suggestions. Seems I have it down to the connectors to the injectors just not sure how to test them. Is there supposed to be voltage if I turn on the switch or do I have to cycle the engine to get the voltage?
Old Jan 11, 2021 | 05:09 PM
Cogswell's Avatar
Cogswell
You should have a pulse signal at the injectors while cranking the motor. You might try a volt meter across the pins, or each pin to ground to see if you are getting a signal.
Old Jan 11, 2021 | 05:44 PM
GalvTexGuy's Avatar
GalvTexGuy
Why did you replace all those components in the first place? In other words, what first went wrong to convince you to replace the components you replaced?
Old Jan 12, 2021 | 10:38 AM
Magnut1's Avatar
Magnut1
Prior to this no start, did it back fire, then run really high idle for a bit? If so, there is a little cap that goes on a nipple on your intake runner. They pop off once in a while and f-up your f/a ratio
Alexander Pearson
Aug 13, 2020 10:11 PM
rocknride71
2014-2024 Touring Models
35
Apr 23, 2017 02:46 PM
Heavyguns39
Aug 27, 2016 12:08 PM
Angus Bozeman
General Topics/Tech Tips
Nov 13, 2015 10:40 AM
bensonjv
Feb 28, 2010 01:30 AM
