Tank Emblem Adhesive
Old Jan 13, 2021 | 01:49 PM
steelpony16's Avatar
steelpony16
Default Tank Emblem Adhesive
Hey All, Emblems came off easy with 4lb fishing line. Now for the foam/adhesive.
Does presoaking the foam/adhesive make it come off any easier?
TIA
Old Jan 13, 2021 | 01:58 PM
falcontamr's Avatar
falcontamr
I used Goo Gone and let is soak for a while on the tank and the back of the emblems (I was putting mine back on after a paint job). Seemed to work pretty good. WD-40 works also.
Old Jan 13, 2021 | 02:19 PM
steelpony16
It's about 30 degrees in my garage.
I want to rub as little as possible (Vivid Black)
Does the hair dryer and pulling at a 45 really work?
Old Jan 13, 2021 | 02:36 PM
Redbeard719's Avatar
Redbeard719
Yes. Also, if you 'stretch' (gently) the foam as you pull it, it releases quite easily. Just like a 3M Command Strip works.
Old Jan 13, 2021 | 03:02 PM
JVS's Avatar
JVS
Pick up a 3M Eraser Wheel on amazon. They are incredible.
Old Jan 13, 2021 | 03:28 PM
RGS88's Avatar
RGS88
Came here to say this as well. I used half a bottle of Goo Gone and still couldn't get the adhesive off. The eraser wheel had it all off in about 2 minutes.
Old Jan 13, 2021 | 03:29 PM
470004's Avatar
470004
Old Jan 13, 2021 | 03:56 PM
scott_0's Avatar
scott_0
hair dryer/heat gun (careful if you use a heat gun) mixed with some elbow grease, some wd40 AND goo gone has worked well for me with body moulding adhesives, there is also this...
this works really well, and will not marr up black paint:
Amazon Amazon
Old Jan 13, 2021 | 04:15 PM
roussfam's Avatar
roussfam
I prefer using WD40 over Goo Gone, I have both. They both work but WD40 seems to take less elbow grease and works quicker
Old Jan 13, 2021 | 04:53 PM
bunk216's Avatar
bunk216
Buy an eraser wheel and save yourself a ton of time and your thumbs from peeling.
