So I need to no oil, trans and primary This is what I researched so far just checking.
oil-4 quarts
trans-1 quart
this is the different one Im getting 26oz or 38ozfor the primary any help before I order Thanks.
28oz for tranny..... Half way between full and add on dipstick for primary. You don't want to fill to full mark. Wise to get a service manual....has all info you need for your RG.
2 questions, 1) what year and, 2) did you get an owners manual? My 2013, 103" TC takes 28 ozs. in the transmission, 38 ozs. in the primary with fluid change only (wet) and the engine will take three qts. but on the TC the level is half way between full and add.
This is why you should not listen to the net but get your owners manual for your bike.. Half way is a cold check for starting the bike. The oil level is checked HOT .
If you decide to put 4 qts in the engine, buy one of these before hand. You'll need it to take out a least a half quart. When you over fill the engine, if no ones done the bypass, oil will start start dripping from the air cleaner and make a mess. Like above don't fill it over half way up the dip stick.
Ok so first 2015 rg and I posted 4 quarts to cover what's needed not what I am putting in it. And I was just looking for how much to buy to cover what it requires. Sorry I should have been more clear and its a oil filter change and has a cooler which I think is stock. Thank Again
I too should have been more clear and posted a picture of my dirty oily Turkey baster.
